NEW LIFEP04 RX PACKS 6.4VOLT
HI GUYS
lifep04 rx battery (no regulator required )There will be a flat pack for onroad in the next two weeks .
Dimension H x W x L (mm): 15 x 31 x 85
Im in china at the moment testing the batteries with great results .
Have been tested with 2.4ghz multiple radios including futaba ,spectrum sanwa and ko with no issues .
up to 1400mah and they are lightweight. 45 grams
They will not bulge during charging extensive testing has been conducted and can be charged above 10amps for a quick charge without having to worry about damage .
just last weekend the battery was tested in off road and in a 1hour main it lost 600mah of the 1400mah capacity .
ill keep you all informed about the progress of the flat pack for your 1/10th tourer and 1/8th pan
Very interesting ...
Im using lipo's on my buggy/truggy as receiver battery without regulator on not-high-budget servos with success but lifespan its bad. This life-po sounds great alternative !!, specially after my starter box exploded due to under-discharge my lipo 14.8v batt !!
thanks for the info,
Cya,
Pato Concha
Southamerica
Cya,
Pato Concha
Southamerica
Cya,
Pato Concha
Southamerica
Cya,
Pato Concha
Southamerica
say hello to trey for me .
regards Angelo
batteries are available for shipping as of next week thursday .
Australians must go through there local hobby stores ,the rest of the world please send us an email if you are interested including the guys who have already sent emails as i get 200 emails a day and to search would be a nightmare.
[email protected]
[email protected]
Do you have to have a LiFe charger or can a regular charger be used. I have an ICE charger. It works with nimh and lipo, but does not have a LiFe mode. I appriciate the help.
Thanks,
DJ Apolaro
Thanks,
DJ Apolaro
if you can adjust your lipo voltage at 3.2 per cell like some chargers, it should give you no problems!
Every overseas customer that requested to pruchase a battery or 2 or 3 and has made payment your batteries are on there way via airmal.
thank you once again for your support
regards Angelo
regards Angelo
