Kyosho Evolva
#1261
I run LiPo rx pack (different car tho). I ran them all last year and like it a lot. There are a lot of different cells available and usually not a problem finding a pack that is smaller than the NiMh pack intended for your chassis. A lot more run time than NiMh of the same rating. No voltage loss on the shelf. I use the Novak regulator that has it's own switch. Pack is lighter, so I add lead. It can be placed where wanted for slight weight bias change.
I find that the servos have more consistant power/speed with the LiPo set-up. I don't use them for the weight reduction, but in spite of it.
#1263
Originally Posted by aaron_buran
Acid,
The alum blocks in the rear of the car come in various flavors, there are 2 types from Kyosho 7-2 and 7-3.5... Delta makes some 9.5-2's.
The front roll center cannot be adjusted on the lower pin, but can be modified by changing the upper hangar. Kyosho has 2 upper hangar 03 and 05, so does empire racing (more agressive than the kyosho's).
Thanks aaron and dougday.. appreciate the info.
Acid
#1264
Thanks Aaron and duneland, I was trying to figure out a way to avoid plugging
the connector in and out of the receiver all the time. Switches scare me but I saw and bought a really cool one that has the switch and charging plug built in, it is just very big and I haven't found a good place to put it.
I was buying some new AA batteries the other day and saw a lipo pack in the case and just wondered if anyone was using them. I got some 2500's which should be just fine.
Ended up with a new radio too, it is really dangerous going to Larry's!!!!!!
Thanks again,
Ted
Thanks again,
Ted
#1269
That's cool bro I'm sure it can all be ordered individually . I see there is also an '07 update kit available now. http://www.redrc.net/2007/04/kyosho-...07-conversion/ . Spend Spend Spend , that's the name of the game !!
#1270
Hey Aaron what servo arms do you use. Where can I get them from? I used some plastic ones but they were too loose. And are jo servos the same spline as ko's. thanks
mike
mike
#1271
All,
The 07 parts and converstion kits are in at Kyosho America.
Whynot,
Sanwa, KO and JR servos have the same spline. I use dynamite hardend aluminum horns.
Whynot,
#1272
mike
mike
Ask Mr. Blackketter
#1273
Originally Posted by NitroHead
I use Airtronics servo arms on my ko's with no problems.
Ask Mr. Blackketter
Ask Mr. Blackketter
Mark
#1274
Here are the PN's for the 07 stuff that arrived yesterday.
FM548 Front Body Mount
FMW38S Aluminum Front Body Mount Posts
FM547 Carbon Fibre radio plate
FM312HC Rear Body Mount Assembly
FM546 Rear Upper Suspension Arms
FM549 Carbon Centering Plate for the rear body mount
FM550 Steel Servo Saver Post
FMW104 Complete 2007 Conversion Kit.
#1275
Hey Aaron,
How about the number for the rear lower arms?
