Kyosho Evolva
#181
Page 1
#182
Page 2
#183
Evolva setup sheet English description
The above are 2 pages that I scan from my English setup sheet. Hopefully it helps.
I also use a OS 21 VZR II. It was a gift from my Japanese friend. He said its modified by his friend in OS factory. At its peak, its near to a Max 21 ABC on the straight. However, the down side is that after about 50 tanks its gradually loosing power, so I have to send it back to my friend in Japan to have it worked at again....
Now I use my Max regularly, and keep the OS as a backup. However, whenever I hear someone at the track says "OS engine is not fast enough" I would put on the OS and rip the track with it....Usually people would watch with their jaws dropped.... Shops even told me their sales of OS VZR II increased!
#184
df
#185
Yes I would love to attach a bigger photo, but the file limit prohibits this.....Will send to your email instead later.
#186
[i]Originally posted by jasoncsc
dougday: Yes 0G is elevated camber [/B]
Thanks for the response Jasoncsc.
When I set the elevated camber at .5 deg front and 1deg rear, I end up with 1.5deg front and 3deg rear with the car sitting on the board.
Why use elevated camber and not the regular way?
#187
[email protected]
#188
Originally posted by Pro Models
HI JASONSC,
THANKS FOR POSTING THE SETTING TIPS IN ENGLISH.... HOWEVER THERE IS A SLIGHT PROBLEM, THE PIC IS TO SMALL AND IT CANNOT BE READ. DO YOU THINK ITS POSSIBLE SENDING ME OVER THE SCANS IN A BIGGER FORMAT TO THE FOLLOWING EMAIL ADDRESS PLS : [email protected] or maybe trying to post them again in a bigger format.
HI JASONSC,
#190
Having a similar reading from the wheel on the ground and the wheel in full bump would be a good thing...It shows that you have all the suspension pivot points in the right place to keep the camber constant as the wheel goes up. Droop (the wheel hanging down with the spring off it's perch) is not as important because your wheel rarely travels this far down in racing curcumstances.
Just for the record, I'm setting my front and back at 1deg. (wheels on the ground) and getting even tire temps and wear.
#191
jkestler, Bocal, Pro Models & NitroHead: I've sent emails to your accounts with the scanned files at 1:1 scale. Enjoy!
jkestler: I received a bounced back message from your server saying that the mail is "suspected spam blah blah blah".... Let me know if you could not receive it.
#192
Jason,
Can you please send me one too?
[email protected]
Thanks in Advance.
#193
pls send me a copy as well [email protected]
#194
Originally posted by jkestler
I don't have the setup explaination in english yet but this seems strange. When we are talking elevated is it up off the ground or the suspension in full bump (the wheel up off the ground). The camber on the setup sheets is the same on the 0g and the 1G. if you raise the chassis off the ground and let the suspension hang you won't get similar readings. If you push your chassis to the ground your readings of camber at the wheel will be more similar to the free state. SO, when we say "0g is the reading off the ground" do they mean wheel in full bump or in full droop? My vote is the wheel off the ground.
http://www.mytsn.com/publ/publ.asp?pid=4937&ccid=8
#195
HI Jason,
Received your mail with the scan....great !!!!!
