Serpent 710
Originally posted by cyba888
ttso
What time did you leave Silverstone today, I stopped by on the way back from Danshui around 5 but I guess you left already. I saw a guy with a cap on but it was a Oakley cap and he had a MTX-3 with yellow body
ttso
Too bad I can't make my clutch work today...
I did copy everything to roll centers and sway bar stiffness. I dont think its my ride height cause I use 4mm and it doesnt rub much on the bottom. Im guessing it could be the droop which would make the car lift more on the turns.
Originally posted by markp27
Blue as in JP-FX blue?
For me, at the most would be a new blue heatsink OS engine.
Re: Re: Re: Re: rear anti-roll option
Originally posted by KevinS
I use the 1/8 scale blade type adjustable rollbar from Serpent on my 705. I put my Dremel to work and narrowed the blades down to 3mm over the whole length, or it would be too stiff. Then I polished the blades to take the Hudy spring steel brown color off the rest of them too. Looks and works great!
Originally posted by ttso
Haha.. I left at about 4:30 or something.. Maybe see you next Sat or Sun..
Originally posted by rcpanama
Just for does ho are interested the following is the weight difference for this Serpent Options:
Part Number Aluminum weight / Original weight
802155 Bracket Middle Shaft Alu 6 g / 5 g
802136 Bracket Radio plate Support Alu 14 g / 7 g
802241 Anti Roll Bar Levers Alu Orange 7 g / 4 g
TOTAL 27 g / 16 g
This weight is with out any screws in the original as the option parts, this could have an error of +- 1 g
TOTAL 27 g / 16 g
Originally posted by Sow&Steady
I think you've nailed it!
Originally posted by GoldFinger
The "mother snake" is only 1700 no fuel w/P Transponder.
Mine, bone stock, titanium screw only on topdeck and pro wheel axles weight 1710.
Re: Clutch.... help...
I got some strange problem on clutch today.
I was using black shoe and yellow spring (I think it's stock, is it?). The stop-accelration is ok, good punch. But once its in speed, re-accelration is extrememly bad. I tried loose the spring, no work. Than I tried a brain new black shoe, a little better, but overall still no good.
The clutch gap doesn't seem effect the problem at all. While I losing the spring, the gap become smaller (is this correct??? Im kind confused), but doesn't change the strange behavior.
I guess I might need to try a new flyweight?
Also, mid-range acceleration, given all else is ok, depends highly on engine tune and capability. Some engines have very poor power band ... tapers right right off after about mid-rpm.
Originally posted by InitialD
Don't rub it in !
Don't rub it in !
Re: Already posted?
The fixing kit has the number 802338 and the two new bars, 802337
Originally posted by PSI Racing
My car could live with a little extra weight.
I hear all these good things about the yellow clutch shoe. At my lhs they sold out but once they are in I want one! Whats the part number for the harder spring that runs good with the yellow clutch? Oh wait..I need the part number for the yellow clutch as well. Thanks
A Yamada modified one perhaps?
Yamawhat? Yeah right...
