Serpent 710
Originally posted by InitialD
I used the Serpent Bearing Oil on the last time I changed the internal bearing of my Max. I used to use a thicker motor oil (Mobil 1) but I figured that the bearings only need lube during starting at low RPMs and that the fuel should already provide lube through the castor and synthetic lube after that.
How the heck do you get the bearings out though? The back one isn't so bad, I just put the engine in the oven, but I don't see how to remove the one inside the engine
Originally posted by markp27
Yes, of course
Yes, of course
Yes, when the crankcase is hot, just hit the crankcase on a piece of wood to dislodge the inner bearing out.
Knock on a piece of wood !
I took it up to 150 Deg C - do I need to heat it further?
Originally posted by jhigga15
I was wondering if you can use WHITE LIGHTNING lube insted of the serpent one-way lube and the graphite Grease?
thanks
thanks
As for the graphite grease, the reason why people use it is because it's dry power based and does not attract dust. I do not use it but I use silicone lube and Serpent Bearing oil for general lubing. For ball diff balls and thrust bearings, I use the Mugen Super Grease.
thanks
thanks
But the best grease for the Centax thrust bearing is definately the Mugen Super grease
that stuff is really good - comes in a nice big tube, too
Hmm, I'm not familiar with white lightning lube - maybe Marcos can help?
Originally posted by tranced
Lemme tell ya one thing.. that super grease is very sticky, be careful!
Also I can really recommend the Serpent bearing lube - I've lubed all my bearings with this and also all metal parts which pass through the bearings, i.e. the one-way, diff, middle shaft, etc. and now my transmission is silky smooth and really free
Takes a bit more maintenance, but the results are worth it. Oh yeah and the for the dog bones, I use the bearing lube - see the FAQ for Rob Kuijper's tips on lubing
I believe he's priming up the car as we speak for the "big" day tomorrow !
Perhaps all of his articles has gone with him to Kyosho !
You and crashed_1 can go hand in hand !
we're fighting the good fight
Ummm, somehow I cannot find all his articles on mytsn...
say it aint so
thanks
thanks
