Serpent 710
#736
Re: Re: Down graded
Originally posted by markp27
The alu bracket isn't required - I asked Michael this already:
#737
Re: Re: Re: Re: Re: Re: Down graded
Originally posted by Diesel Racer
Fair comment Michael, and despite what the Mugen guys think there is none better than Serpent and it sure is better to lead than to follow. Now I wonder if they will have a clone out for the Winter Nats.
#738
Re: Re: Roll Centre & Ackerman?
Originally posted by MichaelS
the car features adjustable fornt AND rear rollcenters, but not adjustable Ackermann.
#739
Originally posted by ub
I am a kind of amused following this forum. Okay, Michael likes wine, Rene doesn´t like orange. But didn´t it start with the seven-ten?
#740
It is apparently the ex-KHM car and it seems he got rid of the battery pack - instead the batteries are placed on the chassis (so, glued on) around the fuel tank area.
Or perhaps get a special custom made KHM RCtech edition with an orange heatsink for the 710!
#741
I really need to rebuild my 705 to attempt to get rid of the tweak. It's not a weight distribution problem, as I have an MSP Tweak Station and from that I can see there is no tweak in the chassis - I think maybe one of the arms is binding a little.
Also makes sure that the distance between the wheels to the center of the chassis is the same and equal on both sides.
#742
I would say that a solid front axle is only an advantage on very specific tracks. But normally a one-way front end should be better - and on very twisty tracks a front end differential could help to improve. I drove my 705 only with a one-way.
Now, I'm testing out the solid front for myself on the Impulse PRO. I've got it close to how I would like the car to be with a one way front but with 4WD brakes ! I find that somehow in the middle of a sweeper, the car slows down a little compared to when using a one way. Tight turn ins and apexes are a thing of the past on this car with the solid front. However, I'm still in the middle of testing it.
My conclusion since just now is that the solid front is good only if the car does not have to do sweepers and S bend chicanes. I guess the track that Mark drives favours a solid front more than anything due to a number of apexes after a straight run !
#743
Belt Question
Just shooting a wild question at the Team Drivers...
What are the number of teeths the 3 belts are having? Also, I notice that on the rear of the 705, 22T brake pulley and 47T diff pulley combo uses the same stock 23T brake pulley and 46T diff pulley combo.
So now with the 710's 24T brake pulley and 45T rear diff pulley, are the rear belts the same? Or is the 2 speed shaft on the 710 at a different location relative to the 705?
#744
Overdrive Question...
Was the 710 tested with different overdrives and tire split? I think this was asked before by some...
Anyway, puching some numbers in, I believe you can run the 710 with a 4 mm split to get 1:1 overdrive when using 23T rear side pulley instead of the stock 22T.
#745
InitialD, "Mr. Post-O-Matic"
Having problems posting. Can't wait to get to "Tech Elite". Install the "InitialD Post-O-Matic" software and you'll be "Tech Elite" in mo time.
Anyway, I've been thru this thread since day one. Its been very informative. The questions I had about the 710 has been anxwered.
And its great to see the people from Serpent here, Michael, Julius and Rene. Thanks guys.
I got one question, what will price of the 710 be?
#746
that all depends on what size your tyres are you can go from a .995 to 1. depends on mm of tyres frt to rear
#747
Originally posted by InitialD
Blame it on the dutch guys and not forgetting that sole guy from Nuremberg !!!
Still not quite getting the hang of the one-way though - spins too easily under breaking. I'll keep at it to see if I can get any better at the breaking.
#748
Perhaps somebody should get KHM online ! We could get answers and engine problems solved by the engine guru himself !
#749
Mark, the arms should be free moving and without binding.
I think I'll start on my 705 rebuild - I doubt I'll get to drive it again this year - not now that I've found the carpet track Another great racing place only 30 minutes from my home!
#750
Originally posted by Julius
Yes, it's a picture of KLM's brand new Boeing 777. I took it during a training flight at Chateroux france.
