Serpent 710
#6586
This is Slavens setup at the winternats04.
Front Roll-center position upper arm (mm): 2mm under.
Does this mean the spacers is on top? Raised or lower roll center?
#6587
#6588
Originally posted by Julius
It means 2mm spacers beetween the part that holds the pivot pin and the bearing block. This is the stock position.
#6589
Cox049
cking to see where you are racing at im from maryland and I run at Dougs track and drive a serpent myself.Im running 12th scale right now and getting ready to go to the nats in 2 days when I get back I'll be getting ready for the nitro season at dougs and the various tracks around the area.I'll be more than glad to help you with you car(and any setup tips) when I start up racing nitro again towards the end of april just give me a pm and let me know everybody knows me in the area and the guys that switched to the 710 are waiting for me to run to give them a hand on setups and all for the tracks cause I only run serpent and have had yrs of experiences with setting them up see ya at the track
Dave aka (SNAKE) my real name not a joke
#6590
#6591
When parts get warmer they flex more and thus break less. In case of the rear a-arm however as the part gets hotter it gets more flexible thus allowing the thread to come out more easily.
Needless to say we've already made changes where nescessary and the strengthened parts are becoming available.
I was going to mention that Serpent have been working to fix this but didnt want to state something based on hearsay. We have had no problems with the 710 in Ireland. Our track is built inside wooden board and metal fence surround and the infield is made up of several islands which are made using road marking paint built up in layers. So the cars take a lot of abuse
#6592
Whats the deal with the "serpent Kai"? I can't read the website? Is the rear shock tower thing they have suppost to cure all the problems with breaking the shock tower? Is this "Kai" any good? Never heard of them before
#6593
Super Moderator
#6595
Re: Cox049
I was at Doug's yesterday, it was closed for pre-season repairs .
I'll PM you
Thanks!
#6596
Another work in progress ...
Folks,
Head over to http://rc.kel-ain.com , a site still being worked on by me.
I'm open to comments and suggestions. You can download MarkP's FAQ there also.
Cheers!
Cheers!
#6597
Dear Julius,
Thank you for a chance of a great discussion.
I wanted to make clear that my previous post is not to say that "X brand is better than Serpent", but to point out my experience with the 710. My experience might not be inline with the mass, but I don't think I am a loner either. Yes there are weak points in all things, and which is better than which is a matter of personal opinion and experiences, but I do feel that something could be done even better. I see the 710 as a step stone for a good change in Serpent, that's why I buy it at the first place.
While I bid my farewell to my 710, I will keep an eye on the coming Serpent, and if I see one I like I will give it a try for sure! Let's see when the 715 or 720 comes to the market....
#6598
Julius,
I have just ran my 710 for 1st time at my local track. The car was quite impressive about performance and gearing.
But I'm having a problem with Traction Roll that I was using 37 , 59-60mm and some of my friends are usiing 42 and even 45, We still had the traction roll at some highspeed corner with red or blue spring. What we should do to solve the problem? raise up the rear roll center ? play with small tire ?
Any idea ?
Any idea ?
#6600
Where can I get those kai parts?
