Serpent 710
#4576
Originally posted by ammdrew
It just will not hold up when you try and poush the 1/8 scales out of the way because they are slowing you down..
#4577
First part of my 710 turned up yesterday - unfortunately just the spares and the decal sheets which I ordered
The suspension arms are noticeably smaller than those from the 705.
Looking forward already to the big box turning up
However, it is just aswell that my 710 isn't here just yet, as we had another heavy snow fall last night
#4578
#4579
Originally posted by cyba888
All you need is some snow tires for that track and your all set
#4580
I sat up last night cutting groves and putting stubs into the Foams
#4581
the 710 was more durable then the 705 or pro ever were drive train whys, we put threee gallons of fuel through the cars at winternats, and never fixeed one drive train part.. belts and pulleys are fine.
#4582
You think the new 710 tanks will be available as an option part? Will the old tank have more capacity than the new ones since there is an internal filter?
Just that the old one did not filter smaller particles and that is why an external one is needed.
As always, Serpent will not come out with a new part number for the tank. I'm pretty sure of that. They will just replace the tank with the one with the bronze filter. I think if you buy them as spare part, you would probablt get the new one.
Else, if yours is not broken, there is no need to change. Just keep using the external filter with it !
#4583
Originally posted by Proficar403
Has anyone felt the need to change belt tensions from "default" yet?
The only "complain" I have about the front and rear tensioner is that it only allows one notch for tightening the belts. No more.
On a side note, I think I ran my side belt too loose last weekend (mine set to the minimum tension). Going from the missing tooth at the side belt, I think the belt skipped. The front and rear belts are still stock from the box and the tensioner is still at stock position. Very free drivetrain.
#4584
Originally posted by InitialD
The stock is fine because after a while the belt loosens.
#4585
<SNIP>
. . . if you go to a race like this and you are way off pace you usually end up replacing most of the parts on the car.. as the 1/8 scale cars will try and remove them without tools...
only parts we ended up putting on the car were lower and upper bumper plates and we deserved all of them.. It just will not hold up when you try and poush the 1/8 scales out of the way because they are slowing you down..
<SNIP>
That sounds dangerous/expensive for both parties, yeah!
#4586
How do you adjust the tensioner for the front and rear?
#4587
Read the manual on page 7, Step 1.9 for the front and page 11. Step 3.3 for the rear with regards to adjusting the eccentric hubs.
I cant seem to find the instruction manual and setup manual for the 710 online. Do you have a link to it? The links are playing tricks on me
#4588
#4589
Thanks for the tip Do you carry the insturction manual with you as well?
Cheers, Mark.
#4590
Setup book
Instruction Manual
Reference Guide
