Serpent 710
Old 01-13-2004, 03:58 AM
  #2926
Sow&Steady's Avatar
Originally posted by InitialD
And yes, he also used the softer red shock membranes.
Ah! That explains it a little bit .. I forgot about the red membranes!
[/B]No problem. I was trying to digest them too when I chatted with him ! Imagine being tired and all after practise. He was nice and patient to sit and talk about the setup. He said he did not play with the shock angles and other stuff. Perhaps there are many different ways of attacking the problem. [/B]
Imagine if we all had his patience! Not only will the Serpent teams around the globe be unbeatable, we'd all be working for Serpent too!
Sow&Steady is offline
Old 01-13-2004, 03:59 AM
  #2927
Sow&Steady's Avatar
Originally posted by markp27
MR D, your mail box is full, I can't send a PM to you
Mark, I guess Master D is getting a lot of PMs asking what else Master Salven had to share re 710 secrets!
Old 01-13-2004, 04:25 AM
  #2928
markp27's Avatar
The man is just too much in demand!
markp27 is offline
Old 01-13-2004, 05:47 AM
  #2929
Company Representative
ammdrew's Avatar
Trader Rating: 25 (100%+)
last year we got nothing right.. burned up two motors in quals.. ( top of piston melted off) limped a old worn motor through rest of quals to never finish a qualifier.. out of fuel with 30-40 seconds left.... all of that, of course, is right on us as a team for not getting our stuff together...
first main walked away from the field.. no problem even with the brand new j-tech running too rich and stalling every pit stop. decided to put it in 30 minutes before the main.. it was our slowest motor but it did have good milage and we were not comfotable with the temps that our fuel hungry worn monster was requiring to make power.. at least not for 30 minutes..
second main almost one, got a broken shock on the first lap, kept the car in the fight for the lead, the stalling did not help, and with the broken shock could not get the inside of the carousel down.. the stalling hurt, as after every pit the car would stall sometimes only three feet out of pit row.. managed to work the car to the heels of first, and go almost a lap down at the pits, get back to the heels, go a a lap down.. with 4 minutes left and on the heels of the leader.. looking to pass in a lap or so the exaust manifold seal tore and the motor went lean... that was about it, but the setup is right on, the car was wonderful to drive and would run with anyone on the track... our motors were not making time...and we asked a bit too much out of them... Ft Myers is the kind of track were if you go to far you can actually melt the piston top off.. but the track is incredibly fun to drive.. you can just humm a tune and find rythem and goooooooooooooooo..
and the hardest part is getting yourself to slow the car down for the carousel and dogleg because the fast guys are not doing it fast they are braking.
ammdrew is offline
Old 01-13-2004, 06:07 AM
  #2930
InitialD's Avatar
Sorry Mark. Please send your PM to me.
InitialD is offline
Old 01-13-2004, 07:32 AM
  #2931
Sow&Steady's Avatar
Man ... sounds like just my kinda track!
Old 01-13-2004, 07:46 AM
  #2932
ammdrew's Avatar
it is definatly one of my favorite tracks I have driven of all time...
ammdrew is offline
Old 01-13-2004, 08:24 AM
  #2933
Sow&Steady's Avatar
You very lucky!
Old 01-13-2004, 11:32 PM
  #2934
InitialD's Avatar
Default Michael's Setup Sheet for Srinakarin Track in Thailand
For those interested, I have attached Michael's setup sheet. In the final, he ran all red springs. He mentioned that he did not like it very much compared to the yellow springs he practised with. Also, I think the camber should be a negative figure. Not positive. Perhaps Michael should have already woken up from his jet lag and comment on the setup he made.
InitialD is offline
Old 01-14-2004, 09:25 AM
  #2935
how can you get a copy of a blank set-up sheet
half-car is offline
Old 01-14-2004, 09:47 AM
  #2936
Thaasman's Avatar
Post
There is one with the 710...
Try to copy it...
Thaasman is offline
Old 01-14-2004, 11:21 AM
  #2937
EVOLUTION's Avatar
Default Re: Michael's Setup Sheet for Srinakarin Track in Thailand
Do you have this in pdf or a larger jpeg?
EVOLUTION is offline
Old 01-14-2004, 01:09 PM
  #2938
chachi's Avatar
Default Novemega engines
Have any of you had a chance to drive and compare the following Novamegas?
2105TMS NovaMega SX12 3P-RE Race Turbo MS
2106 NovaMega SX12 SS 3P - Turbo
2104MCP NovaMega SX12 5P-Race MCP
Are there any major differences in terms of performance?
I currently have the 3P-RE Race Turbo MS and am very happy with its performance. It seems to outrun most other high-end engines at our local tracks, plus it is reliable. I will need a new engine this year, so I would like to know how the various Novamegas compare.
chachi is offline
Old 01-14-2004, 01:40 PM
  #2939
S710_Nut's Avatar
Default Setups?
Talking about setups, On the weekend the car was pushing a fair bit si i went down a hold in the front shock piston, the car was better under brakes and easier to drive, but my best lap time was slower then before i made the change. I do not know if the weather had anything to do with it as the later the day went on the hotter it got? I was thinking i should change the shock pistons back and try more front camber? Suggestions?
SN
S710_Nut is offline
Old 01-14-2004, 02:04 PM
  #2940
clmbia45's Avatar
Default Re: Setups?
SN
Try raising the DRS up; shortening the rear anti-roll bar; tightening the diff.; lower the front roll center; disconnect the front anti-roll bar.
clmbia45 is offline
