Serpent 710
#2041
Re: Serpent 710 Pics - Part 5
Originally posted by InitialD
#2042
Serpent 710 Pics - Part 17
Final one.
#2043
Re: Re: Serpent 710 Pics - Part 5
Originally posted by Julius
I would suggest using countersunk head screws on the front shock tower. This looks waiting to break.....
Should not be a problem if I set the shocks straight right?
#2044
PM
InitialD, I've been trying to send you a PM but your mail box is full.
#2046
Re: Re: Re: Serpent 710 Pics - Part 5
Good observations Julius ! That is actually temporary until I can get hold of M3 countersunk allen screws that would be long enough to fit through the spacer behind the shock towers.
#2047
Re: Re: Serpent 710 Pics - Part 13
Originally posted by PUNISHER
Hey D,
Is that a hollow 2speed shaft in that pic!?!?
If it is did it come in the kit?
Thanks for posting pics of 710!!
Hey D,
#2048
Re: Serpent 710 Pics - Part 17
Final one.
Final one.
#2049
Re: Re: Re: Serpent 710 Pics - Part 13
It looks hollow from the 2-speed side. There is a grub screw inside to hold the pin in position so there is no way it can become jammed between the 2-speed shoes.
#2050
Who is Mr. D?
For those who have been asking D who he really is then seek and you shall find!
Look carefully at his pics, the brilliantly polished Shark pipe might just reveal who he is!
#2051
I just spend 5 minutes to CAD out the idea of the steering linkage diagram that I don't quite understand completely...so you guys can tell us (and me) what exactly should we position the servo horns and the right linkage length....I don't have the 710 yet, but I would like to address this problem now so I don't have to dig out these thread when I start building the kit in may 2004...
From my 14 years of RC experience, I always believe the servo horn setting MUST BE positioned 90 degree perpendicularly align with the Servo linkage, NOT to the servo position if we want to maintain the equal amount of LEFT and RIGHT steering travel.....but I can be wrong, since the servo position itself is in angle, but I am very much sure the Diagram "A" should be the one to use......about the length of the linkage, you guys who got the 710 should post the right dimension here.
#2052
I go for "door nr" A
Nice diagram's Rookie Solara. I wish i could make those
#2053
I believe Julius already address this............It depends on what (witch brand) of servo you are using. As long the epa is close to where you need it.
However, nice job on the CAD and your question because I will be in the same boat as you in Spring 2004 when I get my 710.
#2054
Re: Who is Mr. D?
#2055
When will the Ti option parts be available from Serpent for the 710? I would like to know so I can get those parts when I build my 710!!
