Serpent 710
#1996
Re: Re: Steering Linkage Pic 2
Originally posted by Julius
Looks like you missed a spot on the radiotray with the CA-glue on the edges!!! (near the M4 screw at the right front bulkhead!)
#1997
Originally posted by GoldFinger
All above is only my theory and i mount it on top eventually, only because im feeling better..
#1998
With aluminium(stock) balls, especially if the rear camber is set 4 deg. a hard impact from back side of the wheel will rip out arm thread.
This way, the rear bottom aluminum pivot pin NEVER needs to see "more flesh" than required if you're using more camber like -4.
#1999
Originally posted by InitialD
Another pic showing a different angle.
#2000
Originally posted by crashed_1
I noticed that you mount your FR shocks on the inside instead of the outside of the front tower...any difference?
Those spacers are inherited from the 705. Since I do not use shock towers on the 705, those spacers are laying around in the toolbox. I found that the shocks are not as straight as they should be (me thinks) when mounted as shown in the manual. It was like that on the Impulse PRO and when the 705 came out, they came with those spacers and the reason for that was the front shocks could be aligned straight and better.
What does Team Serpent think this? Since the 710 was designed from the ground up, why was this overlooked since the bulkheads could be made to shift a little bit behind?
#2001
Re: Re: Re: Steering Linkage Pic 2
#2002
Re: Re: Re: Re: Steering Linkage Pic 2
Damn...you're right...they aren't straight...more wrenching.
#2003
#2004
Did you already rip out a ball or is it more a concern?
#2005
Julius, there is one thing I forget to ask you:
Pls check Initial D picture about steering linkage in normal position.
When I mount the steering rod face up(balls on the top), as the car lean harder it increases the toe in for the outside wheel. At least it will help servo holds this tire in setup position. Which is good for high speed cornering. For low speed cornering the present ackerman angle is big enough to do it smoothly.
If I build it face down (just like manual) the toe change (bump steer) is only happen when you brake hard but not changing the toe setup as the car leans out when cornering.
Question is: Which is better for tight and small track?
#2006
Originally posted by clmbia45
Julius, I've been meaning to ask, I know working for Serpent must be very profitable, but isn't it a bit MUCH to put a picture of your private plane on your posts??
I wish
Actually I am not an employee of Serpent. I test and race for them but I do not get paid.
#2007
I knew Pieter was a tight ass !
#2008
Maybe it's me but: Camber is set with the top pivot ball. More camber means it's screwed in further = more durable. The lower balls are set for track width and toe.
On testing, I switched the upper link to its shortest position(UBO) and made an adjustment(lower ball) to keep 4 deg camber.
In this position, screwing all the way(upper ball) you will only get 1 deg. change.
With this (very much) camber change, i think i hit the jackpot on back side. Then i realize the rear trackwidht is 202mm and nothing i can do since the upperlink ball is screwed maximum. Pyramid suggest me to cut the ball and I did cut 3mm off.
Check my photo, you will never be able to do that without cutting your balls!! (I mean stock aluminium pivot ball)
Then after adjusting the lower ball to kept 200mm trackwidht, my car is even better.
And for the next day Sunday race,before the Final I did put some threadlock on that ripped arm thread. I did Finish without cahnging any parts coz I do not have any of those 710 parts
Is that couraging ?? or stupid ..??
#2009
I doubt that you will be able to clear the steering rod from the suspension. Especially when you run the top pivot block in the lowest position. To be honest we didn't try this. Feel free!
Mount the ball face down and to compensate that you have to mount track rod on the lower side in steering block too
#2010
I wish
I wish
