Serpent 710
#1246
Originally posted by GoldFinger
As someone said in earlier page, that he was a undercovered serpent teamdriver so he do not need to touch his car just telling this and that and his mechanic will do...
p/s: Ok, this is for Mark. That's my secret to a clean brand spanking new car. The real thing. No Photoshop filter tricks !
#1247
Originally posted by fmolzer
I never knew I was teaming up with a forums racing legend. I will have to ask him to sign my trophy when I beat him next time.
#1248
Fmolzer: No sir, acctually it is an old engine with no value whatsoever. I got for free, see, it says NovaMax, they stopped making these years ago. Can I go now?
#1249
Originally posted by markp27
Interesting! So in principle although more droop makes breaking more stable, on a small track you have to use less to ensure that there is enough weight transfer to allow for better turn-in.
#1250
Don't know who you could be refering to, there!
But since I cannot possibly have enough time to work on my cars, I send them to Stanley. He takes care of my car. Rene, Julius or even Michael will set my car up for me when he's not racing or when he's having a lunch or coffee break ! That's my secret.
#1251
Ackerman on 705
Originally posted by Julius
No there is only one ackerman position. We tried different positions and felt the difference was too small to make different options. On the 950 for example the team drivers hardly ever change the ackerman.
#1252
Originally posted by clmbia45
They're probably already working on the 777 Model, so perhaps you should wait for it.
#1253
Re: Re: Bearing sizes
Wheel bearings 10*15*4 mm
Diff bearings 12*18*4 mm
2-speed and middle axle 6*13*4
Cool, I believe only the 10 x 19 x 5 bearings are different when compared to the 705.
#1254
Originally posted by Rookie Solara
LOL (I am sure they can build the 705 from scratch with their eye closed and use only 1 hand while chatting on the internet.........)
But seriously, we are lucky Serpent's online support is top notch. If you were unclear of anything, you could always go to mytsn 705 forums and ask. Imagine what would have happen if the manual suck and there was no online support...
#1255
Re: Re: Re: InitialD 5001 Posts
Originally posted by Diesel Racer
Old Chinese proverb (I think) Better to be the master of one, rather than a jack of all trades.
#1256
Originally posted by Proficar403
It is very interesting to know that serpent acctually considered shaft drive.
#1257
I still love being able to show up with an old impulse SS and show everyone that it is still down to the driver who wins races...
#1258
Originally posted by utopian
I think I would not get parts for my Impulse Pro in next year.
#1259
I'll go to the track tomorrow with my 705 and even though it'll be just above freezing and th track will be covered in leaves, twigs and acorns, I will enjoy driving my 705!
#1260
Originally posted by lawndoggie
Yea I really wanted to feel the power of the brake at full speed, but the track was so small that when I got the car to full speed, it was already the end of the straight...
What gearing are you using? Stock from the box? The stock gearing is too tall for small tracks. It is only ideal if you run like those long flowing European tracks.
Change the internal pulleys to a higher internal ratio one. 23T brake pulley to 22T. 46T rear diff pulley to 47T. 18T rear side pulley to 17T. Also use 50T 1st gear spur (stock is 49T) and 15T 1st gear pinion (stock is 16T). For second gear, use 46T spur (stock is 45T) and 18T 2nd gear pinion (stock is 19T). That would give you about the same 1nd gear final drive ratio as the stock 2nd gear MTX-3 / V1RR EVO gearing.
