Serpent 710
Originally posted by jfc_tech
one more thing...i noticed my steering percentage is different from left and right. left more than right but right is more steering. is my servo limiting it. i put 100% already...
Cut the metal (the stock rod linkage) down to 17 mm. Stock lenght of the rod linkage is 23 mm from tip to tip.
As for the plastic, trim the length of the ball cups. The picture attached shows the top one being the original (and uncut) and the bottom one is the one that was trimmed.
This combo gives the total length of the ball cups and rod linkage assembly as 39.5 mm instead of 44.5 mm as per the manual.
At neutral position, the steering servo horn is not in the center. It should be leaning forward slightly at neutral position with this linkage mod.
Originally posted by Brett.w
Yep it was taken at our big boys toys event you may notice not holes were cut it was just a spare body
Ummm, you need to cut out cooling holes. Else with them touching the car like that, the engine will surely overheat.
Originally posted by InitialD
I bet you kept that shell !
Hey Rwisejr i will be in New York from the 29th to the 7th of dec is there any tracks to go look at and i need a hobby shop to buy engines and serpent parts, any around N.Y. area?
Originally posted by Sow&Steady
Listen, 6 bodyshells without tax is no good without the RRR that you chose to ignore and not bring.
Aren't you coming down some time soon?
Err, so when is the next race down in NZ?
