Serpent 710
Old 10-31-2004 | 01:19 AM
  #18271
Originally posted by Sow&Steady
Brett, that would be a shame. There are others but none as good or as complete as Mushroom for online ordering.
Sounds like it could be a business opportunity for you? Open a shop specializing in Serpent in NZ!
I would go out of business very quickly i would keep all the parts for myself! mind you if i can get hold of that ring you lot keep going on about then it may be a different story!
Brett.w is offline
Old 10-31-2004 | 01:27 AM
  #18272
Sow&Steady's Avatar
Heh! Everything has a price ... just make an offer and we'll see what we can do about the RING. It'll be quite expensive seeing that the RING originated from NZ ... or at least the movie did!
Sow&Steady is offline
Old 10-31-2004 | 03:08 AM
  #18273
Davo's Avatar
Default serpent 710
Dear slow&steady,
thanxz for your reply but i have already raced at lylidale just today it was the V.O.R.T.E.C vic champs i finished 4th overall after a flame out half way through the race. i run 65mm on th rear and 61 and i also have another question what sort of motor do the top guns run? i run NOVA MEGA the only way to go 4 me anyways. once again thanxz 4 replying>
Davo
Davo is offline
Old 10-31-2004 | 06:20 AM
  #18274
daniz24's Avatar
Regional Moderator
I hate to say it but perhaps mushroom is getting out of supplying Serpent stuff and clearing their stock or they know updates are coming for both the 950R and the 710 are coming.
I don't think its possible because he also mentioned the price for the "NEW" Picco Mega engines...
daniz24 is offline
Old 10-31-2004 | 07:54 AM
  #18275
InitialD's Avatar
Is it me or did anybody noticed that rc-mushroom also did not list engines anymore in their inventory? Strange...
InitialD is offline
Old 10-31-2004 | 07:56 AM
  #18276
InitialD's Avatar
Default Re: Re: Dogbone Pin Mod
Good mod D.
Onkle Sow, the mod's not mine. Just thought since it was Friday, I'd take pictures of the mod that was suggested initially by Per-Ola.
InitialD is offline
Old 10-31-2004 | 07:59 AM
  #18277
InitialD's Avatar
Unless any of you guys can reccomend me an asian stockist?
Hey Brett, try PM Goldfinger or Pyramid. I think they can help you out as they did for me...
InitialD is offline
Old 10-31-2004 | 08:00 AM
  #18278
InitialD's Avatar
Default Re: serpent 710
Davo, that's a pretty big split you're running. Why? What pinions and spurs combo do you currently have on the car? If you have 55T, 56T and 57T 2nd gear spurs, you could try pairing them with either 21T, 22T or 23T if you already have them and see which one gives you the best time around the track.
Did you read my reply below to your post earlier?
"I would see what the other cars are running. Check the brand of the car, their gearing, tire diameter and perhaps maybe their pipe and engine. Calculate their tire rollout and compare it with yours. That would be more than close to accurate method.
But I suspect that since most of the guys at your track run Kyoshos and Mugens, you would probably need to back off on the 2nd gear to something like 22/57 or even 21/55 assuming your engine tuning is correct... Just an educated guess... "
InitialD is offline
Old 10-31-2004 | 09:36 AM
  #18279
Sow&Steady's Avatar
I hope its not true too.
Old 10-31-2004 | 09:37 AM
  #18280
Sow&Steady's Avatar
Default Re: Re: Re: Dogbone Pin Mod
Ah OK ... good to give credit where credit is due. Per-Ola it is then.
Old 10-31-2004 | 09:41 AM
  #18281
Sow&Steady's Avatar
That is true! Engine's are gone!
Old 10-31-2004 | 09:45 AM
  #18282
rwisejr's Avatar
Post
Maybe they are updating and reconfiguring their engine pages and layouts ? I hope !!
rwisejr is offline
Old 10-31-2004 | 10:04 AM
  #18283
Sow&Steady's Avatar
I hope so too ...
Old 10-31-2004 | 10:21 AM
  #18284
InitialD's Avatar
Perhaps but I noticed also that you can only buy 190 mm bodyshells... Or has it been always like that previously?
If that's true, they're probably clearing nitro stuff... Perhaps only concentrating on electric car stuff.
InitialD is offline
Old 10-31-2004 | 12:57 PM
  #18285
anyone wanan buy my 710 with x-12 engine for 550 shipped? engine ahsnt even been nroken in yet got racer package on the car also
Bxclip is offline
