Serpent 710
Originally posted by markp27
Took mine apart and cleaned it all last night - I think I had this problem, too.
I think I had the clutch gap set too small and there was too little end play.
This time I rebuilt it with a 6mm clutch gap - as best as I could measure it and left, as Glenn recommended, 0.1mm endplay. To ensure I got 0.1, I added 0.1 spacers until there was no endplay and then removed the last added spacer.
Lets see if it makes a difference
I find that when both my centax clutch and the 2-speed clutch has been cleaned, things a re just .... so much faster!
Originally posted by crashed_1
No worries...sow's on his OS. Heard you got everyone to halt exporting FX engines to the UK...
Mine binds badly. I figured that's the reason why my car does all that wheelies over small bumps on straights. It effects handling badly...
Try unscrewing the set screw that holds the hinge pins on the lower arm. You'll be surprised at how free your arms can be but it's a little dodgy though. I'm doing that to my car and so far so good.
Originally posted by Sow&Steady
Not sure why ... maybe because you're glad I can't practise?
It should make a huge difference.
Originally posted by InitialD
Have you tried to go leaner like 5 or 10 minutes more on the HSN?
Re: Re: Going on honeymoon
Originally posted by packetdreamer
no need to bring the car on the honeymoon... i've already established an international holiday for such things. congrats, congrats. i better start thinking of an annaversary gift for the end of november too. maybe i can get her another 710 for me.
What with that and now that I've set my throttle linkage to actually use full throttle instead of 4/5ths I should be unbeatable!!!!!!!!!!!!
i got the option bag with my kit and so did my freid we paid 369.99 391.04 with tax eadch and had to send in the $%0 rebate. the option back consist of OPTION PACK #100006 QTY, LIST
SER802831 Set-up wheels S710 alu orange (4) 1 37.95
SER801157 Bracket tank-mounting carbon 1 13.95
SER802165 Pully adaptor alu. light (2) 1 13.95
SER802155 Bracket middle shaft alu 1 29.95
SER802325 Pivot inserts lw mid-pos (8) 1 5.95
SER802252 Front shaft lock-set 1 5.95
SER802241 Anti-roll bar levers + ecc. Alu 1 44.95
SER909410 Shock-body alu teflon front (2) 1 16.95
SER909411 Shock-body alu teflon rear (2) 1 16.95
TOTAL VALUE 186.55
SPECIAL OFFER PRICE 111.95
this goes to show u that serpent does update the kit cause the first abtch was so messed up parts didnt fit. i drive in aprkin lots msot o fthe time do u think im better of puttin the fornt shaft lock set on for good?
TOTAL VALUE 186.55
TOTAL VALUE 186.55
TOTAL VALUE 186.55
i dunno exactly btu peopel told me serpent at first at messed up sh lata
yo now oen mroe quesiton got my servos in adn when i press brake the servo pulsl the lever towards the front of the car is that correct? cause if it is i got a problem my brakes work when the ever goes tot hte back of the car adn the lever gets push towards the back when i open full throttle . if i got it worng howdo i fix it?
I find the yellow cluth definitely wears. Not as dramatic as the black but it sitll wears a little more. Tkae your pinion clutch bell out and look at your clutch, if it does not appear to be wearing out then its probably glazed and is therefore not performing as it should be.
Perhaps you like it that way because of the driving style but I guess that's the downside. Some people let it engage aggressively and like them that way. Maybe harder to drive even. If you set it to engage correct, you will not have the clutch wear out.
Re: Latest installments
PD, nice pic ! But I think you need to ask Mark for a trial version of his dirt filter to clean what's on the carb of your engine. From the pics he's been posting, it looks like it works pretty well. I suspect the one he gave me was not working well (whether on purpose or not I don't know... ).
