MTX 5
Old 03-27-2014 | 12:36 PM
  #3091
NITTO550's Avatar
Yes I've seen that too, I wonder if the shepherd has similar chassis tweak issues since the chassis are almost identical
NITTO550 is offline
Old 03-27-2014 | 01:58 PM
  #3092
Smile
Mtx5, Sheperd, Xray,etc, are all victims of my Ntc3.1 son !!! LoL.... Port Jervis this year baby !!! Get ready for the ass whooping......ahahah......
bertrandsv87 is online now
Old 03-27-2014 | 02:02 PM
  #3093
I will be there with mine.
rossb is offline
Old 03-27-2014 | 02:05 PM
  #3094
Smile
Alrighty !!!! Let's go racing....
Old 03-27-2014 | 03:04 PM
  #3095
NITTO550's Avatar
Oh yeah, port Jervis is where you will see me! What's up Bert !
NITTO550 is offline
Old 03-27-2014 | 03:25 PM
  #3096
NITTO550's Avatar
Ross , did u find your problem? You might want to check the diff front and rear and feel if they are smooth or not.
NITTO550 is offline
Old 03-27-2014 | 06:12 PM
  #3097
Not really. Here is a crude video I shot of me pushing the MTX5 (on the right) and a very old HPI R40 (left).
https://vimeo.com/90283023
Both cars are on HPI vintage rubber tires. The MTX5 rolls much better if I take the side belt off it.
rossb is offline
Old 03-27-2014 | 06:52 PM
  #3098
shanwright's Avatar
Default try this.
Try putting the optional 26 tooth side pully on if you have epual diameter front and rear tires.
shanwright is offline
Old 03-28-2014 | 12:26 AM
  #3099
SEEDKNOX's Avatar
Interesting site: amainrchobby.com
This site is apparently selling a Mugen Mrx5 for $264, Mtx5 for $240, Serpent Viper 977 for $272, etc... way too good to be true. In fact, every price on the site is too good to be true. But I have to investigate. Scam red flags are everywhere. Only accepts credit cards, western union, or wire transfer. I made contact and actually received a response from a person named Lina Han. The dialogs begins... I will update.
SEEDKNOX is offline
Old 03-28-2014 | 12:47 AM
  #3100
maver's Avatar
hello
but as it is pull the belt side?
you find it difficult to pass it under the belt tensioner side?
pay attention that some detergents can alter the straps rendodole slightly swollen and then a smaller diameter and this blocks the smoothness
(this from personal experience).
maver is offline
Old 03-28-2014 | 01:44 AM
  #3101
asw7576's Avatar
rossb
Go to the track and test your car there.
Within 10 minutes of testing .... you will notice if the car is doing fine OR there is something not right.
Make sure you install the correct pulley related for middle belts before testing at the track.
asw7576 is offline
Old 03-28-2014 | 05:09 AM
  #3102
blis's Avatar
Default Front to rear ratio
Originally Posted by asw7576
rossb
I'd usually agree with you out of respect, however if he puts it on track with wrong ratios he may trash his side belt and pulleys and you have noted it, I'm re-iterating!
ROSSB:
If the side belt wants to climb off the pulley then there's a mismatch of ratios in the drivetrain when all wheels are on the ground then...
Keep the side belt on the car, put it on the ground and lift the rear and move it forwards and backwards, feel if it rolls well, watch the side belt while you are doing it. Then do the same lifting the front wheels off the ground.
If the side belt wants to climb off the pulley when doing this there may be a misalignment. If it doesnt then the gear ratios front to rear are the problem.
Check the trans-axle's pulley and all the other pulleys (side and front) again and ensure they are all installed correctly and the correct number of teeth.
If all still checks out, go to the speed calculator I wrote and plug in your values for pulleys, tyre diameters and check the final ratios front and rear. Don't enter values the manual states, enter the values of the pulleys as they are on your car.
See here: http://capricornrc.com.au/home-2/lab...ed-calculator/
Lets not discuss what colour the bulkheads are, many of us love the hobby regardless of make and model.
Steve: a 2mm split is a 5mm diameter difference per rotation, and doesnt (Luke just tested it) stop the car from free rolling otherwise in a 30 minute race, we'd all be stripping side belts.
With respect,
h
blis is offline
Old 03-28-2014 | 09:13 AM
  #3103
asw7576's Avatar
Rossb : I trust you.... you have build your car correctly according to mtx5 instruction manual . Sooner or later you have to bring your car to track and have it a road test. I'm sure it will be fine. New build car need break in time. Dont listen to blis too much ..... trust your build and the instruction manual.
Blis : I dont love this hobby regardless of make and model when smart people like you around.... ok?
asw7576 is offline
Old 03-28-2014 | 09:33 AM
  #3104
Smile
What's up Rich !!!! It's still a bit cold outside, but when it warms up , I'll be practicing everyday at FBF !!! LoL !!!! No way to catch me after that....ahahah...... See you.....
Old 06-06-2014 | 04:46 AM
  #3105
FF25510's Avatar
from the japanese magazine, the MTX-6 will release soon
FF25510 is offline
