MTX 5
Old 02-20-2013 | 07:41 PM
  #2701
doctormtx5's Avatar
Originally Posted by reedy126
wat is the difference between the t2oo1 and the t2002
Check mugen website or go back 1 page too see the changed parts
Originally Posted by bigbank66
Doctor 5....who makes that body???? An how did it work??
The body is a kfactory lola shell. Not too sure if they still make them
doctormtx5 is offline
  #2702
NITTO550's Avatar
I think the biggest difference was the steel diff gears, and a few other things. Someone please correct me if I'm wrong.
NITTO550 is offline
Old 02-20-2013 | 07:46 PM
  #2703
doctormtx5's Avatar
Here are updated parts
I dont use steel gears now
Originally Posted by doctormtx5
included in T2002 kit:
T2227 Diff. Gear (Steel)
T2228 Diff. Cross Shaft (Steel)
T2103L-B Rear Upper Arm Bulkhead L
T2103R-B Rear Upper Arm Bulkhead R
T2111-B Rear Upper Arm Mount Plate
T2201-B Diff Case
T2215-B Brake Disc Adaptor
H0753 Spring Cup (Steel)
not included but consider:
T2407
High Traction Chassis
T2715
One Piece Engine Mount
Old 02-21-2013 | 12:02 AM
  #2704
mick8488's Avatar
Hi Guys,
Have been running the Plus 12-3sct with a 2652 pipe combo for the last year in my MTX5, but have struggled on getting 5mins of runtime (even with gas cooler) and poor bottom end acceleration. Recently switched to a Max Power 2649 pipe and very impressed with the difference. Now reaching almost 6mins and the bottom end is ballistic! The 2649 really makes it scream!
Has anyone else noticed this with the 2652 pipe? Is it thirsty?
Cheers,
Mick
mick8488 is offline
Old 02-21-2013 | 12:56 AM
  #2705
Bishop's Avatar
Originally Posted by mick8488
Hi Guys,
Cheers,
Mick
If it's the pipe I'm thinking of, yes terrible fuel economy, I could barely make run time with anything I had mine on.
Bishop is offline
Old 03-02-2013 | 12:03 PM
  #2706
CanyonCarverR1's Avatar
I'm getting ready to put together a new MTX5 and have a question about servos.
How does the car balance laterally with standard vs low profile? I'll be using a LiPo battery.
CanyonCarverR1 is offline
Old 03-02-2013 | 02:08 PM
  #2707
doctormtx5's Avatar
well it depends.. which high voltage (low profile) servos are you thinking about using?. I use low profile servos on my 5 and the balance is alot more even then running standard size servos... I have tried both setups and there is a big difference on control of the car. With low profile I find it easier and more reactive
Old 03-02-2013 | 03:59 PM
  #2708
I haven't decided which way to go but these might be an option:
http://www.amainhobbies.com/product_...oly-Compatible
Do you have any recommendations? I suppose I could use LiFe.
Old 03-02-2013 | 04:42 PM
  #2709
NITTO550's Avatar
If I were to choose a low profile servo, it would certainly be those. Also use the 7.4 lipo for the power especially on steering.
NITTO550 is offline
Old 03-02-2013 | 04:51 PM
  #2710
doctormtx5's Avatar
good choice.. there is a slight modification you will need to make inorder for them to fit correctly... the platic servo holder (inculded with kit) is really tight around the servo wire area when you try and put both servos into the holder.. You need to slightly modify the servo case where the screws are put in... If you use standard servos the wire coming out of the servo will not be an issue becuase the servo is larger and the wire is lower on the servo... msg me if you need more info on this.
Old 03-06-2013 | 07:22 PM
  #2711
hi I have just changed front belt on grandsons 5 and I would like to watch the bloke that can do in 15 min I can't get the bearing of unless the dam diff is out I thought merlin was dead ended up taking one side off like 4r
greg
greg.dawn is offline
Old 03-08-2013 | 10:03 PM
  #2712
Hey guys,
Any reviews from the high traction chassis?How it affects the car handling?
Tracks in Greece are low to medium traction and I am wondering if this chassy is suitable for us.
tonyhalandri is offline
Old 03-19-2013 | 03:05 PM
  #2713
its time we had a new page
Old 03-19-2013 | 03:38 PM
  #2714
shanwright's Avatar
Talking A new page
shanwright is offline
Old 03-19-2013 | 04:21 PM
  #2715
i just order the update kit should will it still need a brace for the flex
reedy126 is offline
