MTX 5
Old 10-31-2012 | 02:44 AM
  #2491
kest's Avatar
Thumbs up
Just arrived..thanx to TRACKSIDE RC
kest is offline
Old 10-31-2012 | 05:10 AM
  #2492
cnc man's Avatar
great to see kest, hope you like it, mesh your gears well and keep your engine bolted down tight and you will be good to go!!
cnc man is offline
Old 10-31-2012 | 06:02 AM
  #2493
kest's Avatar
Thumbs up
Thanx again dude..nice work. Already installed..neat !
kest is offline
Old 10-31-2012 | 06:13 AM
  #2494
cnc man's Avatar
fantastic, thanks for that, was'nt that easy to put on? now i bet you can't wait for the weekend to come soon enough to test it out.
cnc man is offline
Old 10-31-2012 | 06:17 AM
  #2495
kest's Avatar
Thumbs up
Easy as 1 2 3..hahaha.. and paul..thanx for the tips.
kest is offline
Old 10-31-2012 | 06:25 AM
  #2496
cnc man's Avatar
anytime
cnc man is offline
Old 10-31-2012 | 06:37 AM
  #2497
cnc man's Avatar
and i forgot to mention if you have the brakes turned up high like normal you will probably not make it to the corner like you thought and undercut the apex. they are very effective now, and take a little bit of dialing out, and you should find they are nice and consistent to.
cheers
cnc man is offline
Old 10-31-2012 | 02:21 PM
  #2498
shanwright's Avatar
Thumbs up Spend some time with setup
These braces are the best single addition for a 5, but just Remember you may need to work on your setup again. I change sway bars, drop, rear camber front drop , etc. and this thing is on rails now. Diff oils !
Steve h
shanwright is offline
Old 11-01-2012 | 02:09 AM
  #2499
Arahawak's Avatar
Steve h
Hi.. Does it handle very differently when you first bolt on the brace without making changes to your set up?
Arahawak is offline
Old 11-01-2012 | 03:38 AM
  #2500
Bundy_Bear's Avatar
It would do as you have reduced the amount of flex in the car
Bundy_Bear is offline
Old 11-01-2012 | 05:21 AM
  #2501
NITTO550's Avatar
From what I understand, the new chassis and the old one are both 3 mm. Do they weigh the same?
NITTO550 is offline
Old 11-01-2012 | 02:06 PM
  #2502
hi bailey did not notice mutch change with new brace but we ran a brace before but car is much stiffer now it was much better on gears
greg
we already had it set up for race motor and not a tg like other people
greg.dawn is offline
Old 11-01-2012 | 03:10 PM
  #2503
Jeff Hamon's Avatar
You will notice a bit more understeer when using the brace without changing your setup, however as steve mentioned a few changes to the setup and you will be faster then before.
Jeff Hamon is offline
Old 11-02-2012 | 07:30 AM
  #2504
YLLIB's Avatar
I still think this is the best way to go, it allows the chassis to flex side to side. When I drove the car I never stripped out a car after putting this on.
I do think that part is pretty trick.
www.acornracingusa.com
PRODUCTS FOR SERIOUS "NITRO" ON ROAD RACERS
YLLIB is offline
Old 11-02-2012 | 07:32 AM
  #2505
YLLIB's Avatar
sorry pic
YLLIB is offline
