Old 09-04-2012, 05:48 PM   #2386
Seisick's Avatar
so a friend of mine was stripping lots of spurs, nothing seemed to worked, so i checked his car and suggested to remesh the gear every often, and adjust them closer, he was surprised to see how close i suggested him , i explained to him that the spurs will adjust after a run and that was it, not a single spur on 3 days of racing for him! btw his chasis ! so basically there are some guys that are lucky to not have issues! and as i said before this kit is for no beginners and requires lots of details to work perfectly, but once is sorted ouT! its as fast as any current top of the line kits! with mugen quality of course!
good luck racing!
HobbymaniA
GoT MuGeN?
Seisick is offline   Reply With Quote
Old 09-04-2012, 09:34 PM   #2387
at last the page is the right size again as i have said the car is very good when it is sorted some times it needs lots /lots of patience but not every body has problems we had very little trouble that was not my fault in set up////some times
i gust am grumpy old bugger
greg
greg.dawn is offline   Reply With Quote
Old 09-05-2012, 02:35 AM   #2388
djiewie's Avatar
Stripping spurs is something every brand has. i`ve stripped 4 spurs in half an hour before i knew what did it. replaced the clutch bearings first, just a little play noticable.Then the 2e gear bearing, just a little play also. Then i glued the bearings from the gearbox in the upright. The bearings were a little loose but it was enough to strip 2e spur with power. (car was a NT1 by the way 2009 version). Gear mesh is with a piece of paper between the spurs en clutchpinion.
djiewie is offline   Reply With Quote
Old 09-05-2012, 02:26 PM   #2389
Chickentrader's Avatar
I have never ever stripped any gear that wasn't already worn out in our Capricorns and Kyoshos we used to race; unless there was something else wrong with the car that caused it. I must however admit that we've had issues with with two other brands of cars. But then again it might have been lack of experience that caused it in the two other brands.
Inherent problems with any car; and the manufacturer's response to emerging problems, are usually well documented on public forums like this one however. Mugen has identified the problems with stripped spurs to the use of hard belts, so using soft belt will obviously prevent gear stripping.
Kindest regards,
Lars.
Support your local RC stores - they support our sport!
Social media The empowerment of the small individual to enforce democratic process at the expense of dishonesty.
Chickentrader is offline   Reply With Quote
Old 09-05-2012, 04:52 PM   #2390
is that right it is as easy as using the right bra to big to small or not flexible// rubber enough i wish it was that easy but if mugen said that's the problem than they had better tell the people that use rubber belts what to do now
greg
Old 09-05-2012, 08:46 PM   #2391
NITTO550's Avatar
The belts? Sounds good, but the mesh and alignment has done it for me. By the way, I've been running the same stock belts all summer without a sign of fatigue . I really like this car. I'm glad I switched
There are only two ways to do things. The wrong way or my way!
Rich D..
~Mugen Seiki Racing MTX-6 ~,
Novarossi racing Engines ~Ko Propo, ~Avid Bearings..
VBC Racing Wildfire D07 ~LRP Electronics ~ Fantom Racing
NITTO550 is offline   Reply With Quote
Old 09-06-2012, 08:17 AM   #2392
Seisick's Avatar
same here, urethan all the way, gear meshing and checking every once in a while does the trick! but i must say play on the 2 speed shaft at 0.1mm, almost no space between the 2 speed shoe and the housing, plus some other tips!
good luck
HobbymaniA
GoT MuGeN?
Old 09-06-2012, 09:17 AM   #2393
I have a question about the 2 speed shaft play. Does the play in your Mugens increase after one or two days of practise?
Radiopost TS401
SebO is offline   Reply With Quote
Old 09-06-2012, 09:38 AM   #2394
NITTO550's Avatar
I actually have my shim between the first and second gear , not at the other side. Like this i have had zero problems, except chassis bending due to the type of starter box
Rich D..
Old 09-06-2012, 01:06 PM   #2395
Hi, did you find some info about how was the new chassis on Euro 2012? How Pietsch like it?
majk is offline   Reply With Quote
Old 09-07-2012, 05:04 AM   #2396
Dont worry about the chassis all i want is the new material for the spurs how far away are they?
baldy is offline   Reply With Quote
Old 09-07-2012, 05:08 AM   #2397
Yes
Old 09-07-2012, 06:30 AM   #2398
shanwright's Avatar
Trader Rating: 25 (100%+)
Yes x2
shanwright is offline   Reply With Quote
Old 09-07-2012, 09:10 AM   #2399
Seisick's Avatar
for sure, as the sparcer on the side puelley is plastic, i now use a 0.2mm shim to obtain a .1mm play on the shaft!
beware youll have to use shims before the cone so to obtain a perfect alingment on the pinions vs spurs, i use a 0.5mm thick shim and i also do the centax gap with 5x7 shims between the outer bearing and the thrust bearing so the edge of the 1st pinions never touches the thrust bearing collar!
HobbymaniA
GoT MuGeN?
Old 09-07-2012, 11:13 AM   #2400
maver's Avatar
http://tuttomugen.jimdo.com/tutto-mt...scoronamenti2/
maver is offline   Reply With Quote
Mugen MTX-3 university_dave Nitro On-Road 17237 12-30-2012 01:16 PM
Mugen MTX-4 Grasshopperr Nitro On-Road 9087 08-30-2011 07:15 PM
Singapore National Series, 2009 Round 2 bullygod Singapore R/C Racers 21 06-27-2009 07:00 AM
Inter-State Racing Competetion Mie3R Malaysian R/C Racers 510 08-12-2008 10:41 PM
INTI College 1/10 Gas Touring (Sarawak,Kuching) LAKIA Malaysian R/C Racers 41 10-18-2007 06:46 PM
TQ With Serpent 720 on 23 & 24 December 2006 in Miri weechor Malaysian R/C Racers 119 02-01-2007 07:04 AM
LRP Nitro Masters 2006 Malaysia HPC II Malaysian R/C Racers 435 06-28-2006 09:03 AM
