Rc10ntc3
#8926
using Kimbrough spur gear
Originally Posted by FREELANCE_RCer
Nobody makes 28T pinion gear for NTC3. But instead of using bigger pinion to go fast, use smaller 2ND speed spur gear. KIMBROUGH makes 46T and 44T 32 pitch gears that will fit the NTC3 with some few modifications, part # 116. I used this before at sun valley speedway and it really works, insanely fast.
#8927
Originally Posted by raceblast
Freelance_rcer, when u used the Kimbrough spur gears at Sun Valley, How many teeth are the 1st, 2nd spur gears and pinion gears? Did u use stock ntc3 clutch bell? Did u mix associated 1st spur gear with kimbrough 2nd spur gear?
#8928
Hi
Seems to be alo of aussie guys on this thread running the NTC3, were are you all getting your parts from. I usually buy online, but not much in HK, only on tower hobbies etc...
For someone looking at getting a FT kit, are there any other major parts required to make the car more relibale before hitting the track etc.
Look forward to hearing from you soon.
BB
BB
#8929
the only thing that i have done to mine was i went out and got the K factory aluminum servo mounts (the FT AE one are fine as well).. and i basically eliminated the servo saver....i just glued the little things together instead of the one screw which would always come loose no matter what you put on it.....im not sure if it comes with the 3 shoe clutch or not but if so then get it....and get the "fix" which you could find on ebay probably........
i have one QUICK Q for anybody......i already have the FT 3 shoe clutch and the hardened springs .....how could i get a little more punch out of the car....the motor is tuned perfectly ....???
thanks
Mike
thanks
Mike
#8931
Originally Posted by bhambrent
Does anyone know where I can buy "the fix" for a NTC3?
#8933
thanks
Mike
#8934
ntc5 ???
Did anyone catch the article in this month's in Xtreme rc mag. Associated has a new top secret electric car and it's BELT DRIVE. The nitro version shouldn't be to far behind. it debuted at the Reedy Race of Champions race
#8935
I race my ntc3 locally and i am looking for my next upgrades. I am thinking about a 3racing 4 mm chassis and a front spool. Could someone who runs a spool give me an idea of the handling changes? I race on prepped asphalt on Jaco foams 40f 35r usually. fairly tight track, one long straight.
#8936
running a spool in the front will make your car push alot more......
#8937
I would drill a little hole in the shoes, I have the 2 shoe clutch and it works great. havent even had to put in the heavy springs. BTW how good is the 3 shoe clutch? what are the advantages?
Mike
#8938
CrazyRonny
#8939
<<edit>>
http://www.tamiyausa.com/articles/fe...article-id=182
according to that the reedy race of champions isnt until the 23rd of July - but practices have been run maybe it was at the practice perhaps
#8940
Is anyone still using this car? I finally blew the dust off of mine and took it out for a spin.... We really don't have any organized Nitro racing here but I like to go run the parking lots with it...
