Rc10ntc3
#7576
has anyone tried the part# 3985?
#7577
building AE shocks
hey guys.can someone explain to me how to refill them???to be honest,i never really succeed in refilling shocks .please teach me step by step.thanks
#7578
Re: building AE shocks
Or... using TRF shock instead...
edit: typo
#7579
NTC3SLCG radio plate prototype, field test photo
Got chance to do the field test with new RX location today, no more radio intereference problem...
The weight without body is 1623g (with AMBrc transponder and 25g balance weight under battery position). With body goes to 1724g, 1g lighter than IFMAR rules. Need to add 5g under battery to meet the rule next time...
for ntc3freak:
I might do small production run (less than 20 I guess) if I can find a good quality with fare price factory to manufacture for me. My prototype doesn't come with good quality and I did lots works to correct the manufacture flaw. I will let everyone know if I can find a good factory for small production run.
for ntc3freak:
#7580
Re: Re: building AE shocks
Originally posted by ttso
Just do what manual said. If you found it's too difficult to fill the shock oil, try this: drill a small hole on very top of side of shock cap (beware the location, don't block the mounting area), fill the shock as manual said, put the cap on, refill it again through the small hole, than find a screw to close the hole up.
edit: typo
edit: typo
can u pm me for step by step instructions?i read the manual,but i still cant figure it out.thanks.please
#7581
Re: NTC3SLCG radio plate prototype, field test photo
for ntc3freak:
for ntc3freak:
if u want to build it,let me be the 1st in ur book of people who want to buy.hehe.cant u improve the wiring?looks a little messy
#7582
Re: Re: NTC3SLCG radio plate prototype, field test photo
and can u make it a 1 piece tray???i think it will make it stronger.no need to use the pesky plastic braces
#7583
Re: Re: Re: NTC3SLCG radio plate prototype, field test photo
If you frequently reassemble your NTC3 like I did. You will find one piece radio tray is no-good because everytime you disassemble radio tray, you need to take front tower off (3 screws), plus 6 screws on radio tray. With AE stock graphit brace, all you need to do is 4 screws (with my design; AE stock graphit tray still be 6 screws). It's much easier for your front-arm, especially when you got a servo failed in middle of race...XD
As for wiring, yes, my new design on paper already have extra wire hole in front of RX hole to let all 4 wires (battery, steering, throttle, and AMBrc transponder) goes through. I will hand cut the hole first see if it's ideal solution for wiring...
#7584
Re: Re: Re: Re: NTC3SLCG radio plate prototype, field test photo
There is reason why I still using AE stock graphit brace: Accessibility
oh.yeah.ur rite.havent tought about it .cannot make a graphite brace ah?
#7585
NTC3SLCG radio plate prototype, wire hole
After 2hrs drilling, sanding, the wire hole finally finished. Now the wiring looks lots better...
#7586
Re: NTC3SLCG radio plate prototype, wire hole
wow.when will it be available???and cant u milled it??i mean trim the unwanted sections to make it lighter.can ah?
#7587
#7589
I have a brand new assembled 2033 kit with sirio .12
with hight torque high speed strg servo 1200 mah batt pack
and sets of the fix for sale never been run on the ground.
take 395 for it!!!
take 395 for it!!!
