Rc10ntc3
#5808
i work for a hobby town in MN and there telling us it is not yet avalible. i was going to buy that but ended up getting the team kit the only thing i think is really worth it will be the factory pipe and ti turnbukles other wise it preety much the same.
#5811
Hey, I'm waiting on my ntc3 factory kit to come in. With the toe in fully adjustable in the rear, can someone tell me how you set the toe in on the car to be equal on both sides? Do you have to have some sort of a tool for that or does the kit have a way of setting it so that it's precise?
Thanks!
racer-oZ
Thanks!
racer-oZ
#5814
"The Fix"
I've read about these on here before and tried doing a search but couldn't refine it enough, but where are these available from?
#5816
Problems with tranny
I've got a starnge problem. Over the weekend I rebuilt both my front and rear diffs. Last night I went to run the car to make sure everything was ok. I noticed that when the car picks up speed the shaft and diffs no longer turn. the pinion and spur gears still turn, bu nothing else and the car doesnt move. when i let off the throttle or put on the brake i sometimes here a click and then everything starts running normally again. then as i pick up speed it happens again. could it be a bearing in the 2 speed or something wrong with the diffs. When this happens, the shaft doesnt even move.
#5818
Re: Problems with tranny
#5819
#5820
Thanks!
racer-oZ
Thanks!
racer-oZ
