OFNA LD3 pro
#1201
Originally posted by Diva
True except that the effect of #30,000 on LD3 diff is like #3,000 on others like Mugen. But you have the solution, don't you?
#1202
Depends on where the crack is. Try cleaning it really good with denatured alcohol and use some strong epoxy or JB Weld. Let it set up overnight and it should be good.
Congrats on your race results. I was going for my third win. Ah well, there is always next time.
#1203
Speedline Race
Congrats to OFNA drivers Jeff Lin and Steve Nguyen for their A main performances at the Speedline Race this past weekend in Las Vegas. We had 5 drivers in the top 20... Barry Baker was unstoppable in sedan I must say though. Jeffrey tested the new prototype CD3 a bit also, but ended up using his trusty old LD3 in the main. Paul Coleman again drove the soon to be released Hyper G4 and narrowly missed the A and the bump up position. Chris and I had a rough but fun weekend, but I think the Team as a whole is looking good. It was my second race with the LD3, and I'm still learning the car, but it's getting better every time I drive it. Can't wait for the next race.
http://www.4acesracing.com/RaceSet.htm
#1204
Re: Speedline Race
Good Job, Jeff and all OFNA Drivers. I know jeffrey Lin end up using monotuning Tires.
#1205
wow! congratulations team ofna! now thats exposure for the LD3! thanks kevink2 and more power to you guys! ..just wondering, what happened to josh cyrul (4 laps)?
#1206
#1207
Hi, Kevink2:
I saw you did very good. Anyway, do you have any old body left.
Not sure, but I hit him hard on the start when he spun immediately in the dirt, and he didn't last too much longer after that. Ooops. Sorry Josh.
#1208
Originally posted by monokenny
Hi, Kevink2:
Hi, Kevink2:
#1209
No, I do not know why recently I like green and light green? Do you one like that?
Maybe a white one Ken.
#1210
#1211
Diff Assembly Problems
Hey guys, i'm sure this has been asked and answer, i'm sorry but i can't find it.
I am installing the diff and after putting both halves together and i tighten the screw down all the way the diff is still very loose. What am i doing wrong?
Also the ball bearing that you use on the diff (U7) is that a purple ball bearing or is that the open one that is in the bag. What i mean by the open one is the bearing that you can see the balls on both sides.
Thanks guys i look forward to your replies.
#1212
sorry
sorry guys wrong thread!
#1213
Re: sorry
#1214
Re: Re: sorry
Originally posted by InitialD
In different times, you'd probably get stoned for doing just that !
Good show Ofna! Did you get a chance to sneak a peak at that CD3? Which side are the electronics on? The two CAD drawings have them reversed. I hope the setup is similar to the LD3 (electrics on right, engine on left). Getting a right hand pipe will be a pain in the rear (a la FW-05)
#1215
Re: Re: Re: sorry
Originally posted by spenzalii
ahahahaha!
ahahahaha!
