OFNA LD3 pro
#1036
Originally posted by dtm
If you want to be different try the Kawahara TC shell.........
#1037
Re: Ld3 pro
Originally posted by Local racer
Hey let me guys ask you somthing do you have a problem with your oneways blowing out.
havy
#1038
th. servos
do you guys ever bust a throttle servo in a ld3?I keep busting mine...3x!i dont know whats wrong,all settings are ok, no over travel of servos,no forced servos either!!!!...what gives???!!!and oh, all are digtal servos,but not metal gears.any help is greatly appreciated.
#1039
ld3 lola body
does anyone know of any lola bodies for the ld3
#1040
If everything is set up correctly no reason the servos should be failing...
what brand?
I run 5 KO's and one Sanwa, never had a problem yet (touch wood). Used in tournig cars & 1/8 buggy..
what brand?
#1041
what brand?
what brand?
that is why Im having a hard time figuring it out....jr ds811 servos.now im just going to use standard ones.I love the car! everything is ok but the th servo issue.
#1042
Only thing I can think of is your working the brakes to hard, overloading the servo?
#1043
you might have set the saver too stiff or the steering servo is of lower quality (less torque)...........
#1044
Manticore, I didnt know the throttle servo had a servo saver :P
Someone is reading too fast
#1045
the saver is the spring !!!
#1046
Originally posted by Manticore
I give you a new one and you give me this one !! you wont be using this painted one anyway !
#1047
Re: th. servos
#1048
Also if you are using the std or Pro chassis...make sure the bottom of your servo is NOT touching the chassis...suspend it higher about 1mm off the chassis......otherwise it gets a lot of vibrations up the arse!!
#1049
Bah, ok you win
hahaha
hahaha
#1050
How about I swap you the RC game!!!!
