OFNA LD3 pro
#421
Re: LD3
Originally posted by KJB racing
hey i brought a LD3 RTR version and i was wondering how ya ment to run it in propally becase i took it for a spin and didnt no that u had to run it in and i was drivin it like 3/4 speed so should i still run it in or what should i do
#422
can you give me more information then that thanx im new to this sport so i dont really no what your talkin about lol thanx alot
#423
#424
ok thanx for that so it wont wreck my car that the first time i used it i was doin like 3/4 speed without runnin it in propally
#425
#426
so if i keep runnin it at bout 3/4 speed for about 1 litre or 2 it should be run in good or wat should i do to get it so its runnin the best it can, and the fastest it can go
#427
#428
Originally posted by SirioInside
So interms of the pro they hadn't changed much? Also I will be getting the LD3 Pro. WIll that be compatable with a rear exhast non p/s SG SHaft engine?
#429
How's the overall performance of this car compared to FW-05R n V1-RR EVO...?I'm a bit half hearted in getting this car...
#431
Originally posted by ernestf
for the LD3 Pro owners : do you fit all 3 shims on one side of the rear diff according to the manual ? this make the whole rear axle very tight with the gear box.
right side - 1xstandard shim + 1xhalf thickness shim
#432
#433
R and RR Evo. Simply depends on how good you are at setting the car up...
One immediately noticable difference is when the gears have run in the car will carry much more speed during off power than the belted cars....this is probably true of the FW05R also....
#434
Oh yes....also depends on which engine you put into the car.............
#435
Originally posted by dtm
The car can be setup to run better or worse than the FW05
