Kyosho FW-05R
#5221
Originally Posted by ch4dwick
do 05RR hex hubs break easily? are there any hop-ups for this? Brands? Part numbers? I saw some on the net but they're not for kyosho. Are these hubs universal in size for Nitro touring cars?
#5222
what's the part number?
#5223
Originally Posted by NiMo
I'm still using the original plastic items on the front end, and 3racing ones on the rear.
#5224
I found the part but which one do I choose? there's the 0mm and then the 1mm offset.
#5225
I use 0 offset
#5227
What are those offsets for?
If you are still running the FW05R rear hubs with 0mm offset wheel shafts (as in the Rubber version) then you would need the 1mm offset ones to fit the 30mm foam tyres.
#5228
I just got my 05RR up and running. Everything is good except that I cannot hear the 2-speed shifting. pulled the trigger slowly and I am pretty sure it is not shifting. I had it set at 1.5 turns out (like manual) and then tried 2.5 turns out. I seem to remember someone saying on this forum that they had to loosen the 2 speed up quite a bit to get it to shift with this car. What are you all out there set at?
JEFF
JEFF
#5229
When mine was new I had to set it to around 3 turns out but now that is has had use it is set closer to 2 turns out.
Just watch it doesn't catch on the 2nd gear else you'll get a nice deep groove in it.
Also I now run the 37T gears so the shaft spins faster before it changes up to 2nd gear.
#5230
I have the 39t Steel ring gears installed and I think I am going to need 37s. This 05RR revs to the moon fast. I can't imagine using 40t gears. What could 40's ever be used for? Maybe a track covered in fly paper???? Anyway I took the 2 speed back apart to make sure that I had the thing set right. I reset it to 2 turns out just to see and still no shifting so now I will try 2 3/4. I see that if I have it set at 3 turns out, the cap screw does hit the inside of the housing.
Jeff
Jeff
#5231
hey guys. im looking at getting a FW-05RR and i was wondering if the OS TZ .12 3-port will fit in it and what are all the things i need to get in order to get the chassis kit on the street?
#5232
JEFF
JEFF
#5233
It is possible to see the performances, this type of CONICAL
5 fins manifold - short type (best solution on long straights)
6 fins manifold - medium type (suggested to have more push exiting curves and on the straight)
7 fins manifold - long type (more power exiting curves)
Choose your weapon
Choose your weapon
#5234
Hi Guys,
Does anybody know where I can get parts for a conversion of my 05R to 05RR especially the front upper suspension arm holder without changing my carbon upper deck, ive seen something like it before here in RCTech but cant find the pics anymore...
Thanks,
K6
Thanks,
K6
#5235
Originally Posted by k617nu-b
Hi Guys,
Thanks,
K6
Thanks,
K6
Not sure if you can find what u exactly want but good luck anyways.
