Like Tree4Likes
Kyosho FW-05R
Old 10-12-2004, 11:11 PM
  #3181
mikecatts's Avatar
Trader Rating: 18 (95%+)
Default pushing
hi all.
im using 35 fronts and 37 rears..with the softests front spring (light blue ) and sway bar..the hardest rear spring ( silver 1/8 scale) the new copper sway bar..RRR front and rear hubs..
its still a fight to get it around fast..
mikecatts is offline
Old 10-13-2004, 12:30 AM
  #3182
InitialD's Avatar
Default Re: pushing
Pushing on or off power?
What's your rear toe in? Front and rear camber? Are you able to adjust the rear roll center with the RRR hubs?
InitialD is offline
Old 10-13-2004, 01:13 AM
  #3183
ziggy12345's Avatar
Originally posted by BundyMan
With 37 shore upfront (2mm smaller) and 40 Rear, I have minimal pushing problems and plenty of steering
If you look at the weight distribution of te FW you will see its rear end heavy, this is the reaon for the pushing. With a decent setup it can be eliminated completely. here are the list of thins to improve steering
More front droop (Off power steering)
Smaller tyres up front (off power steering)
Softer compound up front (On power steering)
less front roll bar (On power steering)
Less rear toe (Both)
28mm rears (Both)
Remove the rear roll bar (I dont know why this works on the FW but it does!) The car has to roll at the back to get the front to work properly i think
Cheers
ziggy12345 is offline
Old 10-13-2004, 01:16 AM
  #3184
ziggy12345's Avatar
Default Re: pushing
hi all.
Sounds like your rear toe. What is it? And try taking the rear roll bar off
Cheers
Old 10-13-2004, 01:46 AM
  #3185
InitialD's Avatar
Default Re: Re: pushing
That would make the on power steering even worse isn't it?
InitialD is offline
Old 10-13-2004, 02:25 AM
  #3186
ziggy12345's Avatar
Default Re: Re: Re: pushing
Thats what I thought until i took it off.
Cheers
Old 10-13-2004, 04:56 AM
  #3187
mikecatts's Avatar
Default FW ISSUES
i run using the efra rules on foams.
i know thew fw was designed for rubbers and slapped together for foams without much thought ( typical kyosho and im starting to get peed!).
More front droop (Off power steering) DONE THAT
Smaller tyres up front (off power steering) DONE THAT.
Softer compound up front (On power steering) ANY SOFTER TAN 35 AND FORGET RUNNING A 20 MIN FINAL
less front roll bar (On power steering) TOOK IT OFF..A REAL PIG,,VERY, VERY TWITCHY
Less rear toe (Both)NEED THE GRIP..2.5DEG MIN
28mm rears (Both), WILL UPSET THE SPLIT
Remove the rear roll bar DOESNT SUIT MY STYLE..TO MUCH IN THE FAST, QUICK DIRECTION CHANGES ON OUR TRACK. YOU ARE IN SECOND
GEAR AND HAVE TO GO THROUGH 2 CHCANES,,VERY HAIRY..
Pushing on or off power? OFF AND HIGH SPEED ON
What's your rear toe in? 2.5 MIN
Front and rear camber? 1.5 FRONT, 4 REAR
Are you able to adjust the rear roll center with the RRR hubs NOPE..USED THE LOWER BLOCKS AND DIDNT IMPROVE, PREFER THE HIGHER REAR BLOCKS,,
Old 10-13-2004, 05:42 AM
  #3188
Super Moderator
Marcos.J's Avatar
Trader Rating: 239 (100%+)
Default Re: pushing
hi all.
have you tried standing up the shocks?
Marcos.J is offline
Old 10-13-2004, 06:34 AM
  #3189
mikecatts's Avatar
Default shocks
yes i have tried to stand the shockers....no better
Old 10-13-2004, 07:33 AM
  #3190
ziggy12345's Avatar
Hmmm.... 2 deg toe in is MAX for me.
30K diff oil in the back? with front one way?
I think you have tried everything. Try the RRR that supposed to be better ....LOL... (i might join you!)
Cheers
Old 10-13-2004, 08:13 AM
  #3191
NiMo's Avatar
MikeCatts, I think you are running a too softer compound, try going 37 front 40 rear.
I ran at a cool 11C with 40 front and rear with only 1.5 degree rear toe in and the gold bar, the rear was planted but the front pushed a bit under hard power, it was with a diff up front and even size tyres.
I'm also running the very soft V-one S springs, Green front, Yellow rear.
NiMo is offline
Old 10-13-2004, 10:02 AM
  #3192
jeffreylin's Avatar
mikecatts, no chassis is suitable to any and all driving style. I do know that the FW-05R consistantly TQ at the Silverstone Raceway and have done very well in other places. The RRR looks to be another top performer. I have both the FW-05R and the RRR and I like them both and I do better with either the FW or RRR depends on the track. The FW does seem to do better with high traction surfaces.
jeffreylin is offline
Old 10-13-2004, 10:44 AM
  #3193
mikecatts's Avatar
Default FW ISSUES
HI ALL.
30K diff oil in the back? YES
with front one way? YES
Try the RRR that supposed to be better ....LOL... (i might join you!) AM GONG TO
I think you are running a too softer compound, try going 37 front 40 rear. NO GOOD,does the same on all tracks and all compounds...
Old 10-13-2004, 10:54 AM
  #3194
NiMo's Avatar
Default Re: FW ISSUES
HI ALL.
I don't have a clue what you'redoing wrong, I find that I have to run at least one compound harder than the opposition as the car itself produced too much grip.
Maybe the answer is your driving style, you might be too aggresive for the 05, so a belt car may suit you better.
Hope you find the right car soon as buying kit after kit can make you lose interest in the hobby.
NiMo is offline
Old 10-13-2004, 11:16 AM
  #3195
ziggy12345's Avatar
LOL... thats what keeps me interested! RRR coming soon
Cheers
