"pillow balls" NITRO TC3
#16
Well I am not completely finished as it is work to get the steel ring gear to fit from a LD3 Ofna but I got it. The only reason I don't have the pinion gear on is that the NTC3 shaft is .060" smaller than the pinion I.D. I have a solution for that too. I will take a solid piece of steel stock and make a shaft that will work using the Ofna LD3 pinion. In the photo, you will see that the left side bearing is not seated against the lower diff case, that is only because I had not shimmed the carrier on that side in the photo. It is now complete and seated like it should be.
three50zx, that is some great information there man. Thanks for sharing.
