Kyosho V-ONE RRR EVO 2
#1248
the evo 2 wc is the better car but the evo 1 is still very good the evo 2 wc has upgraded parts on it. it also has the most steering out of any touring car on the market.
#1251
Yes you can, all the RRR's are the same model just different version.
I have a WC for sale.
http://www.rctech.net/forum/r-c-item...uned-pipe.html
#1252
Pulley 18T and 23T with screw
Hi!
I'm looking for pulley 18T and 23T for middle shaft with screw (no pin version).
I need it, because I made mod for my RRR for nova .12 with roto, I have
one axle with holes for pins but I need new one.
Can you help me and suggest from or where I can got it for my mod?
Thanks!
m.
Thanks!
m.
#1253
Major diff in the 2cars evo1 and 2, the chassis on the 2 is a little narrower and the cross brace in the front has been removed for more flex resulting in more steering, and also in the rear a few of the outdrive parts were changed so the car accepts 0 offset rims. If u want a little more flex from your evo1 u can cut the brace out yourself with a dremel, (that's what I did) Also the evo2 uses the evolva steering ankerman, It makes ajusting ankerman easy but it can't b used with the front diff. So stick with the 10,11,12 from the evo1. I read that the car that won the worlds was a evo1 with the brace cut out. Not sure if he ran the 2mm offset Rear tires or not. The evo1 is a great car, I must admit i did drive my buddies evo2 and it def has a noticable amount more steering but not enough to buy the new chassis. Peace
#1254
#1255
As a matter of fact I did change the upper deck to the one that accepts the NT1 tank, But I did it b4 I ever saw the worlds winning car, I forgot to mention in my last post that the upper deck of the 2 is also a little dif in design, prob a bit twistier to aid in chassis flex. I will post photos when I can, the nt1 tank is nice on the evo. Not sure if it enhanced performance but I do think xray has a better tank. Function/design
#1256
this is wrong Ielasi had the previous chassis.
i have photos.
i have photos.
#1257
I highly doubt he had the evo 2 cause I remember it was alot of talk about kyosho claimin the evo2 was the world champ and it was posted that it was actually a evo1. At that time I think only the team drivers had the 2. I highly doubt lelasi was a team driver with a new platform and chose to use a NT1 tank. Someone with more info will prob clear this up for us cause I'm just goin off what I read
#1258
#1259
Thanks for finding those pics. Not only is that not a evo 2 Its a 1 with the brace still intact, The evo2 chassis is much further away from the steering servo holder that's where the material was shaved from, and the 2 doesn't have that V brace in the front. and those look like twister 2mm offset rears. So like I said a evo 1 did win the worlds!
#1260
2nd place at Turkish nationals
Solved my braking problems thank you.
Now I have some other questions. I had some problems with 2 speed one-way bearing during the race. How do you clean it? Which oil is good for it? ( I use serpent one-way lube ). A tiny drop of oil is ok for it?
Thanks guys
Thanks guys
