Kyosho V-ONE RRR EVO 2
#2746
Pic
Here ya go,working on shaving weight all need is that third body post from the G4RS 09 super easy to install even easier to remove the tank, really gives the car a different look i most say,hopefully i can install those infamous smaller diffs.Thanks to 30Tooth,s insight,next thing i will looking an the KM HK1 gas tank also, will keep ya updated ,an for those that will say just get the car instead of doing all of this to this car ,this car was FREE, FREE.with a ton of parts, an RRR WC roller too.
#2749
#2750
Hmmmm
Thanks for nice comment, i used the tank because i an installing the layed down throttle servo setup, an also mounted the receiver on the left side, an also if the front belt breaks i wont have to take the upperdeck off to replace it,as i stated before the car was free with alot parts that will last me for aleast 2 full y seasons.Lower CG effect was the look i wanted.
#2753
No trying to b a D!?k but you put it out there for the world to see.....since u got everything for free or close to nothing you should really try and have someone cut you a upperdeck with RRR dimensions to accept that team magic tank! Diggity designs can prob do it! Not sure what it will cost, but can't b that much..... Cause i loved the RRR and its killing me to see you monster garage it like that lmao!
#2756
#2758
#2760
