Kyosho Evolva M3
#977
Front One-Way
Would anyone happen to know what are the differences between the SP Front One-Way (FMW28) and the original one that comes with the kit (FM513)?
Thanks.
Thanks.
#979
The difference is that FMW28 seems to be a lightweight version and the one-way bearings are better quality Have a look at kyosho.de you will see the differences.
#980
Sorry I got back to the house late.
Here is the setup
Front
shock oil 500
spring white
shock pos H
scrub set 1.0
caster normal
camber left 4 right 4
toe angle 1.0 out
front width 252mm
droop 0 mm
antiroll bar flat across
tire hardness 32
tire diameter 67mm
ride height 6 mm
scrub set 1.0
Rear
shock oil 500
spring white
spring pos middle
scrub set 1.0
upper arm short/in
camber right 6.5 left 6.5
toe angle 3.0 in
rear width 260 mm
droop 9 mm
antiroll bar stock
tire hardness 35
tire diameter 74mm
ride height 7 mm
sus holder B
rear hub axle / mid /
rear wheel base long
Clutch setting 0.8
Servo Saver position A
lock tight everyting that screws in to metal except the screw that goes in to the top of the radio tray that screws in to the servo saver.
Ti/9mm ball screw set
vzw024v
Here is the setup
Front
shock oil 500
spring white
shock pos H
scrub set 1.0
caster normal
toe angle 1.0 out
front width 252mm
droop 0 mm
tire hardness 32
tire diameter 67mm
ride height 6 mm
scrub set 1.0
Rear
shock oil 500
spring white
spring pos middle
scrub set 1.0
upper arm short/in
toe angle 3.0 in
rear width 260 mm
droop 9 mm
antiroll bar stock
tire hardness 35
tire diameter 74mm
ride height 7 mm
sus holder B
Clutch setting 0.8
vzw024v
#982
http://www.kyosho.de/?page=shop%2Fpr...&search=fmw-28
http://www.kyosho.de/?page=shop%2Fpr...&search=FM-513
If you are looking for other parts, use the enrty-field POWERSUCHE.
For example: FM-513 or FMW-28
#983
According to what I read online, the new suspension mounts reduces the front track width by 1.5mm (not sure whether this is total or for each side), which improves steering response.
The shock mounts improve lap times by adding additional stiffness for high grip tracks.
The new suspension mounts allow the upper arm lengths to be shortened by 1.5mm each side allowing for improved steering response. The track width should/can remain unchanged though.
#984
Here are the 2 links
#987
#988
Hi guys, does anyone know where I can acquire empire front belt tensioner or anyone selling 1? Does it fit the m3 evo? I've been facing front belt stripping with the car. Anyone has other solution in fixing this issue? Anyway all the pulleys are new and I strip at least 2 belts every gallon of fuel.
#989
You should not be striping belts if the tension is set correctly. Use the excentric bearing carriers in the front bulkheads to set the tension. You don't need the Empire tensioner to do this.
#990
i hav a kyosho m3 for sell i hav a tun of parts 7 set of grp tires 35 shor and also empire part and a 1 peace motor mount for novarossi look for 280 or boo thx pm me for pic
