Kyosho Evolva M3
#946
Make sure you have lateral movement on the two speed shaft. If it is too tight, too little movement, it will give you problems. Or, don't snug up the pullies to get rid if any slop - you need a bit of end to end slop
#947
However, I'm not sure I understand your last statement "don't snug up the pulleys"...when you say pulleys, are you referring to the 2 speed shoes?
How much slop would you say the shoes need in relation with the 2 speed shaft?
Thx!!!
#948
Softest Kyosho springs?
Guys:
I am under the impression that the silver fronts and black rear springs are the softest kyosho springs available. Is true?
Racing on a very bumpy track....any recommendations on spring selection would be appreciated.
Thanks in advance!!
Thanks in advance!!
#949
Belt Stripping Problem, advice?
Guys:
Been stripping front & rear belts like crazy since last year.
Max time before both belts strip is 8 mins. Middle belt never strips.
I've tested with ALL the different available belt tensions from softest to tightest with no success. The plastic belts seems to last a little longer than the rubber ones.
Thought this was due to the track that I usually race on, but have tested on perfectly clean surfaces with no success.
This thread doesn't seem to highlight a belt stripping issue with the M3, nevertheless, I welcome any advice.
Thx!!!
Thx!!!
#950
I would suggest that you use the Empire Racing belt tensioner for the M3. It will give you more wrap on the 16t gear. After you get some confidence back, you can then free up the car by running less tension. I also suggest the use a a GOOD Hard Coated 16T gear like:
Serpent 903348
I don't have any in stock right now but if you hunt around you should be able to come up with one.
Remember free advice is worth what you paid.
Serpent 903348
#951
when is the new Kyosho Evolva available
#952
Front Long Wheelbase axle set
Besides extra durability, would anyone know what other benefits the front long wheelbase axle set can provide?
Any handling changes/differences?
Thx!!
Thx!!
#953
I also want it to come soon.
#955
Selling an M3....take a look $350 with electronics
http://www.rctech.net/forum/r-c-item...evolva-m3.html
#956
Guys:
Thx!!!
Thx!!!
How do the pulleys look? Worn metal or plastic pulleys will exacerbate belt stripping problems. And if you can clear the teeth of larger debris between rounds, your belts and pulleys should last quite a bit longer.
#958
The best clutch setup I have on my M3 is the Mugen MRX5 WC clutch set, but use the Kyosho 3D shoes instead of the mugen ones. I had to cut the pins a little on the MRX5 flywheel to make it work but it worked well. I used the CRF spring, the WC yellow mugen shoe and the normal M3 clutch bell.
I have also put the MRX5 front end on my M3. I feel it really helped the front end. I can try to post pictures if anyone is interested.
#959
evolva death?
Who is still hoping that Kyosho will come around and surprise us all next year with the continued development of the evolva platform?
