GT class--buggy-based on road!
#3796
#3797
hehe.. you're right - either way is good
btw, I paint with cans, just good masking tape and a knife is enough
cheers
cheers
#3798
I can't wait to get the 18 and 19 tooth pinnion for my GTE, how is yours running speed and run-time wise?
#3799
true..
Myself..I was using Orion VE (2050KV) and IGW-008 tranny, very nice. Later I lowered the gearing by putting 10T pinion gears with ST-RR ring gears, but I don't think it was worth doing. I should put it back together and try it on our track. Fast for sure.
Currently I'm running the Inferno VE as is on the road close by having a big jump there and having lots of air with my son who runs the Ultima SC10. Much fun!
I kept breaking on steering servo's though (it's a heavy car) but today I bought one crazy Futaba BL servo that can handle 30kg with .14s/60deg at 6V. It was expensive but I hope worth the money. It's the strongest you can get that size (I was told). Handled harsh landings well since.
#3800
I forgot, you are using a 2-speed, what kind of run time do you get, what capacity and how many cells are you using?
#3801
2 x 2S 4000mAh Orion 25C lipo. There are better ones available now from Orion, the carbon series, like 50C, more power output
Runtime was decent, never clocked it. I wasn't running on a track (it was early spring) so I got bored much earlier before the batteries died
With the tranny, you need a brake servo, right. It's an easy mod with VE (just punching a hole to the radio box cover for another servo and connecting it to the aux and mixing with gas/brake. Then taking off the brake&reverse from the speed controller)
#3802
I have a 4S brick pack in mine at the moment. I plan to stick with a single speed and drop in a 5 or 6S battery if I feel the need to go faster. Too much homework to install my servo today, but tommorrow...
#3804
The way I understand, the brushless electric motors turn so many rpm and have so much torque that a single speed works fine.
+1, 4s and "charging bags"
#3805
New Kyosho 2 speed tranny (shoe type) 2nd gear
Unfortunate for me I stripped the second gear on my new 2 spd tranny It's so new gears are in back order for 3 weeks
Does anybody know if I could use gears from an 1/8th scale onroad car? Serpent, Mugen or Kyosho? I hope I can fix it before friday if not I'm going to have to stick with the old version What a bummer!
#3806
#3807
#3809
thanks guys
i think i found a blackhawk body and tires from Ipanema rc, the 2650 kv will go for now but a 1800 will be in there.
#3810
