GT class--buggy-based on road! >
Old 11-11-2008, 12:22 PM
  #1501
-R2-'s Avatar
I put PMT 30's in the front and it was ok it just took a long time for the tires to make more grip but by then the track was drying again and I was pushing more and more then I blew a plug, replaced it and it blew again so my engine just took a dump, it had alot of miles on it and it was a .21 Picco EVO II.
-R2- is offline
Old 11-11-2008, 07:29 PM
  #1502
Erchur's Avatar
I have a Kyosho MP777 SP2 that I would like to convert to a GT. Has anyone done such a conversion? Is it worth the trouble and the $$$$. If so can you share the needed part numbers and place to buy them.
Thanks!
Erchur is offline
Old 11-11-2008, 08:44 PM
  #1503
Thanks!
Eduardo,
Just to let you know Nitro house has the DM-1 pro spec kit car for $330 but with their 20% off till the end of November the kit will cost aprox $270. I think your conversion will run you close to the same, so it is something you should consider....
You will need for the IGT conversion....
1. Bumper set
2. Shock towers
3. body mount set
4. Body
5. tires
6. 2 speed unit (avoid the new 21/40T 2nd gear combo for racing)
I have done a hyper 7 Rally game conversion and it didnt cost me very much. This is what I did...
1. Ofna GTP bumper set
2. Ofna GTP body mount set
3. Strip of carbon fiber to mount the rear body posts
4. Tires
5. Body
I ran the single speed 44T plastic gear for the mp-7.5 / mp-777 center diff and 15T clutch bell. Motor was a OS Speed Vspec .21
Hope this Helps.
vadn1 is offline
Old 11-12-2008, 05:50 AM
  #1504
Originally Posted by ssrods1
THANKS
good win Ron!!! Seems like every one had a good time in kiss. I hope all the races turn out like that!!! Good clean fun!!! NO Crying!!!!!
pit-master is offline
Old 11-12-2008, 06:09 AM
  #1505
The GT class seems to be picking up pretty good!!! I'm seeing more and more DM1's every week! Making the class more competative! GO OFNA!!!!!!!!! Hope to see all the GT's this sunday at SS RACEWAY!!!
Old 11-12-2008, 07:02 AM
  #1506
JLock's Avatar
Jspeed,
Finally got my first official win with the IGT1 at Bvoltz' Big Chill race this past weekend. TQ'ed the class in the last qualifier and lead for much of the 30min main. But, I stripped second gear (seems to be a big problem now with the car) about 8 minutes in and had to hold off the competition with just one gear (won by one lap over second place).
Almost have my IGT2 engine broken in and will have it ready to roll next season. Hope to be racing against you in the very near future.
Juan
JLock is offline
Old 11-12-2008, 09:04 AM
  #1507
BiggDogg33's Avatar
Originally Posted by vadn1
Eduardo,
1. Bumper set
2. Shock towers
3. body mount set
4. Body
5. tires
4. Tires
5. Body
Hope this Helps.
Just A quick question why you say avoid the new 21/40 2nd gear combo fo racing!!!! and what combo do u suggest and why!! Thanks
And hopefully next season we can get alot of GT races at 301 raceway!!!!
BiggDogg33 is offline
Old 11-12-2008, 09:59 AM
  #1508
After seeing first hand a fellow racer go through 3 gear in 3 weekends and reading about other IGT2 owners as well, I have come to the conclusion that the new gearing can't seem to hold up to hard racing enviorments. As for the original IGT car the gears are much better for racing conditions.
vadn1 is offline
Old 11-12-2008, 10:59 AM
  #1509
Zootcapri's Avatar
Originally Posted by JLock
Jspeed,
Juan
Mesh... It's all about mesh. Set it real tight and make sure that both gears are in alignment and you should have no problems. I was concerned about how tight I set the mesh, but, it spun freely. The only problems I have had were when I didn't set the mesh properly, the engine mounting screws worked loose or I trusted the factory mesh setting when I ran the GT2 for the first time. Otherwise... miles of racing without stripping gears...
Zootcapri is offline
Old 11-12-2008, 03:53 PM
  #1510
BiggDogg33's Avatar
Default trying to understand the Inferno gearing!!
Originally Posted by Zootcapri
Mesh... It's all about mesh. Set it real tight and make sure that both gears are in alignment and you should have no problems. I was concerned about how tight I set the mesh, but, it spun freely. The only problems I have had were when I didn't set the mesh properly, the engine mounting screws wroked loose or I trusted the factory mesh setting when I ran the GT2 for the first time. Otherwise... miles of racing without stripping gears...
So U agree that along as you get the mesh tight with the new GT2 gears you will be ok and the gearing is or maybe better for racing compared to the GT1 gearing, with the different gearing from both of the GT2 and the GT1 which gearing will be better for long tracks and short tracks or is one good for torque or rpm's just wanting to know so that I can understand the gearing patterns!!!
Old 11-12-2008, 04:01 PM
  #1511
BiggDogg33's Avatar
Well I also had that problem too, when I first got my GT2 I raced it straight out the box at the I-95 race at 301 and I also stripped 2nd gear and I thought it was because of the mesh because I broke my engine in by taking the clutchbell off and doing it like a break in bench, but before the mesh gave out and the 2nd gear stripped the car looked very good and had great top end speed and was pulling good too I dont know if you all ever been to 301 raceway but it has an awesome straight away and sweeper where you actually can see your motor full potential and the track is HUGE TOO!!!!!! but thanks for your advice and im going to try both gearing from both Infernos to see what I like!!!!
Old 11-12-2008, 04:17 PM
  #1512
Zootcapri's Avatar
I ran the 43/19 (GT1 Ferrari) second for parking lot tracks and the 40/21 (GT2) for big, open tracks.
It sounds like 301 is alot like Vegas... the straight is about 180-190' and all the turns (even the 180's) are wide.
Old 11-12-2008, 04:22 PM
  #1513
Zootcapri's Avatar
I messed up the original GT2 gearing by not checking mesh. Once mesh was set I ran three qualifiers, the B-main and part of the A-main at Vegas (big track). There doesn't seem to be any wear on that gearset. "Think tight mesh and your troubles will float away" (voice from Calgon commercial - soothing bubble bath)
Old 11-12-2008, 04:30 PM
  #1514
impalabob64's Avatar
Default Gt2
Gt2 wins Vegas seen the imfo on Kyosho wedsite.
impalabob64 is offline
Old 11-12-2008, 04:31 PM
  #1515
tbo713's Avatar
hey next year come check out at 301 and also check out the I95 showdown gt cars and you will see our track
tbo713 is offline
