Kyosho VoneR Thread
#9961
Swaybar linkage shot. Also you can see the K Factory belt.........
#9962
Originally posted by Manticore
no no, that's my car amg !
#9963
You have one lovely car AMG !!
#9964
Originally posted by AMGRacer
Esham, get these ones:
From 3 racing for the fw05r
Any opinion on not using any rear sway bar what will be my disadvantages?
#9965
But I think now I mostly have the optional parts which add to the performance and still keep it light...............
#9966
#9967
Is this 3racing antiroll bar really can fix into the Evo RR?
#9968
AMG, did you mean this antiroll bar is suit for the Evo too.. Just for confirmation.
Best to check first before order.
#9969
#9970
For instance, we found a light bar helped when we had a solid rear end in the old "R".
Lately we've run a range of rear bars in the Evo and have settled on a 2.0mm bar. This is a bit lighter than the silver one, I think, and seems to work well.
What problem are you trying to fix?
#9971
AMG, is it the low friction belt ? What is the different.. Material?
#9972
The normal springs for the car (shock springs) control both the front/rear and side/side chassis movements. Without swaybars both of these movement controls are joined together. Ie. if you want the car to roll less you stiffen the springs equally, but this also makes both the front and rear stiffer and reduces front/rear weight transfer.
Swaybars act like "sideways springs". You can set the front/rear weight transfer using the normal shock springs and then fine tune the side/side weight transfer with the swaybars. Swaybars have no effect on front/rear weight transfer. So swaybars allow you to reduce roll in corners, but still have softish springs to allow good weight transfer to the front and rear under braking and acceleration.
#9973
But one thing I want to make sure.. which always bordering me.. Is the rear sway bar will make the car tend to more understeer during cornering ?
#9974
the sway bar serves some purposes. to reduce chassis roll at corner, an effective tool to combat chassis roll due to excessive track surface traction. to reduce undue chassis motion at corner, i.e. faster cornering.
#9975
