Kyosho VoneR Thread
#9796
G4 side belt
Originally posted by AMGRacer
For those looking for a freer drivetrain on the EVO I can recommend the G4 side belt option from K Factory. Manticore put me on to these items and they are quite amazing. Best part is if you already have the SP front and rear belts you can merely change the side belt to get the advantage.
#9797
Over in the G4 thread, someone said that the G4 front and rear belts also fit the Evo. I didn't get an answer over there - can anyone confirm this?
#9798
all the 3 belts are interchangable between G4 and RR/EVO
#9799
Have you tried the front and rear belts yet?
#9800
Originally posted by Taylor-Racing
Like I said . . . . You da man, Manti
#9801
the front and rear belts are not necessary. the long side belt makes the difference.
#9802
Re: G4 side belt
Originally posted by apmk
The G4 side fits which of the 2 side pulleys, 25 or 27?
#9803
Originally posted by dtm
Your pretty looking alloy bits are not necessary...but you still have them on your car!!
#9804
such as?
such as?
#9805
I will be trying the NS5 crank on the the NS3 engine this weekend.....see how it goes. BTW, for those worried about the NS3 engine....don't....the thing has masses of low end torque and goes like stink!
#9806
The list would be too long to go through!! Have you finished rebuilding your Evo yet?
#9807
almost. i need to redo the battery plug wiring which makes my head even bigger
#9808
Use the normal servo plugs and glue it on top this time..........
#9809
Hey there if I may ask for advice? Is the front outdrives on the Evo and the RR are the dog bones the same length. I recently lost one of them and need to know if they are the same because I don't think our LHS carries Evo parts yet. Oh, yeah I'm running a one way in the front also. Does this make a difference in the length of the dog bones? Sorry I'm new at this and need advice. Thanks
#9810
The doggies are longer
