Kyosho VoneR Thread
#6766
V one RR evolution Kit 38000 yen out in June.
Should have picture by May 15th (Shizuoka Hobby Show) under the following links
www.hobby-one.co.jp
Just spent whole life saving on a MTX 3, now I need to rob a bank...
www.hobby-one.co.jp
#6767
OK Brendale setup for those who have asked
Front:
Oneway diff
2 degree camber
12 degree caster
1 degree toe out
10 pitch servo saver
70 wt shock oil
red v1rr springs
high front shock mount on lowest setting
Enneti 40 shore tires
4mm ride height
0mm droop
Swaybar at 45 degree angle
Rear:
Kyosho TCD diff with 10K oil
3 degree camber
4mm spacers under MTX3 rear hubs and lowest inboard setting
2 degrees toe in
6mm droop
4mm ride height
50 wt shock oil
red or light blue v1rr springs
Black swaybar
Front:
Oneway diff
2 degree camber
12 degree caster
1 degree toe out
70 wt shock oil
red v1rr springs
4mm ride height
0mm droop
Rear:
3 degree camber
2 degrees toe in
6mm droop
4mm ride height
50 wt shock oil
Black swaybar
#6768
thanx amg for the set up!
#6769
NEED HELP!!
While i was putting on the engine today on my V one R i found that i couldnt MESH the gears. I tried every position on the engine mounts and moving it side to side and up and down and couldnt mesh the gears. Im thinking that the pinions that were on the 1st gear had smaller teeth and couldnt mesh up with the 49th gear. Please let me know how i can fix this problem because i was schedule to run this car tomorrow.
#6770
set up
Thanks AMGracer for the set up post will try it out, and tell you how I go.
Thanks again Graeme
Thanks again Graeme
#6771
Re: NEED HELP!!
damo
#6772
hey finchy did you get your car fully set upp yet??
#6773
damo just about there now I'm just waiting on an exhaust system should be here next week. Too lazy to drive over the south side to pick it up. Who know what happen south of the river.
#6774
so finchy you like the car so far and what exhaust system you getting??
#6775
so what clutch setting did you set it at?????
#6776
Yeah the car is fairly straight forward to build, parts all fitted nicely no hand fitting required which is a change from most other kits. Just waiting on a Nova in-line exhaust coming over from Mt Gravatt. Other than that can't wait to get it down the track for a bit of track time. Hopefully I'll have better luck with this than the NTC3
Graeme
Graeme
#6777
Well the manual says 2 mm but I'll just set it at 0.5 - 1 mm at the moment I have to run my S3 in on the car so I don't want the clutch too tight.
#6778
if i have probs i will switch back to a mugen gold
#6779
Originally posted by Taylor-Racing
As I understand it, Enetti use Japanese rubber for rear's and GRP for the fronts or something - not sure. I believe the 40's were the issue, here. Our local guys stopped using the fronts but were happy with the rears . . . though it might be the other way around.
What's your opinion on the Enetti's compared to Zac's or Active. ?
A set of Zac costs me almost the same as a complete set for my MRX3, so are expensive.
With all the info I have seems that the Enetti uses a slightly different scheme than Ellegi (and other GRP brands) about using Japanese foam on front and using a quite different foam at rear (the rear used at Enneti isn't European foam - Some said Japanese some said American foam -, wears and grips quite different than the GRP ones).
Only you can do it is love it or hate it. Seems that are getting quite success here and are starting to be used by many racers (some time ago were only few that used).
#6780
So Jeremy do you think that will be set to lose. Took me ages to screw it down to 1mm, that nut is F**kin' tight on that clutch. I think like you said it will be trial and error. Hopefully next weekend will be the debue ( Saturday ) if I can get some fuel by then as well. I wish that tree would turn green a bit quicker
