Kyosho VoneR Thread >
Kyosho VoneR Thread
Like Tree1Likes
Kyosho VoneR Thread
Old 03-31-2003, 04:58 AM
  #6511
Manticore's Avatar
Originally posted by tl2111
I'm using m1rr that's why i can keep up with those mugen
you should be able to adjust your rear end to suite the sweeper.
Manticore is offline
Old 03-31-2003, 05:00 AM
  #6512
Manticore's Avatar
Hey Thomas
Didn't you know Wayne can't pull away from me, only when I self destruct
why self destruct? your secret agent identy at the track was discovered?
Old 03-31-2003, 05:36 AM
  #6513
tl2111's Avatar
Trader Rating: 21 (100%+)
I think is more to do with the body! stratus 2.1 seems to have alot more downforce at the rear then 300m that I normally use but if I use 300m i would trade off stabilty through the infield. still had me thinking
tl2111 is offline
Old 03-31-2003, 05:41 AM
  #6514
Manticore's Avatar
play with the spacer on the rear hub !!!!
Old 03-31-2003, 05:43 AM
  #6515
tl2111's Avatar
yes its strike my head after couple mins of hard drivng can't concentrate
tl2111 is offline
Old 03-31-2003, 05:59 AM
  #6516
VenomWorldOrder's Avatar
Hey Thomas
just joking Tommy i enjoy the chasing. i need to improve my consistency by a country mile before i can challenge you.
VenomWorldOrder is offline
Old 03-31-2003, 09:45 AM
  #6517
Bounty Hunter's Avatar
Default Interesting findings...
Interesting thing that I found out is that the roll center adjustability in the rear accounts for some of the performance that we see from the MTX-3. I have heard from some MTX-3 owners that also run the V One RR tell me that the internal drive train ratios are higher on the MTX-3 and that is why the car seems to be quicker off the corners. I am still in the process of researching to see what those ratios are and to find a solution for the V One RR. May be on to something... Need to test it....
Bounty Hunter is offline
Old 03-31-2003, 04:18 PM
  #6518
T-shirt's Avatar
tom
you should be in mugen MTX-3 thread not here man
T-shirt is offline
Old 03-31-2003, 06:46 PM
  #6519
InitialD's Avatar
Default Re: Interesting findings...
Both MTX-3 and the V1RR have same internal drive ratios...
InitialD is offline
Old 03-31-2003, 06:54 PM
  #6520
kevink2's Avatar
I think the overall ratio is a bit higher on the Mugen Vince. Most of my gearing differences between the two cars have to do with motors (short stroke vs. long).
kevink2 is offline
Old 03-31-2003, 08:46 PM
  #6521
Default Hmmm.....
I think you are right Kevin, I have been going though a driveline ratio formula and it keeps telling me that the standard MTX-3 setups in 1st gear are 6.9 and the V One RR with the same Pinion is at about 7.1. I am still trying to verify that I have all the correct number of teeth on the rear diff. Can anyone verify if the rear diff to the MTX-3 is 48 teeth?
  #6522
Default Re: Re: Interesting findings...
Are you sure about that one? I think they are different. Just slightly though.
Old 03-31-2003, 09:13 PM
  #6523
InitialD's Avatar
Default Re: Hmmm.....
1st gear final drive ratio for the MTX-3 with stock gearing (16T/20T pinions and 47T/43T spurs) is 7.42. Final drive ratio for the 2nd gear is 5.43.
Yes, the MTX-3 has a 48T for the rear diff. The pulley arrangement is as below for the MTX-3 (front at the top and rear side at the bottom);
32T
24T 16T
19T 19T
48T
For the V1RR, the rear is the same with the exception of the front side;
32T
27T 18T
19T 19T
48T
If you calculate either front or rear internal drive ratios for the V1RR and the MTX-3, they come up to 2.526316. So they are the same.
InitialD is offline
Old 04-03-2003, 09:18 PM
  #6524
Anyone know where to get a Rollbar with mounts for the V one R?
Also anyone knows where to get cheap hopup parts for it.
thanks
Got Rice? is offline
Old 04-04-2003, 06:40 PM
  #6525
thanks
Try www.integy.com
HEYALIGNMENTGUY is offline
