Kyosho VoneR Thread >
Kyosho VoneR Thread
Like Tree1Likes
Kyosho VoneR Thread
Old 01-06-2003, 08:17 PM
  #5716
Originally posted by kevink2
Ah the truth finally comes out...
Nah I'm no good. I'm an noobie and an amateur, but yes I am a World Champ...................
<---------------Poster.
Sydewynder is offline
Old 01-06-2003, 08:18 PM
  #5717
patelladragger's Avatar
try steve at speedtechrc.com
or vince at
nitrorc.com
patelladragger is offline
Old 01-06-2003, 09:10 PM
  #5718
Originally posted by Sydewynder
Hmmm I wonder who TC3nut is? Are you the person who asked me to pick up your 3rd place trophy at the Hangover Havoc today?
HEYALIGNMENTGUY:
Do ya know who TC3Nut is?
Nope, never came up and said HELLO , but I do think I beat him in the 1st qualifier
I thinks thats what he gets for SAND Bagging it
HEYALIGNMENTGUY is offline
Old 01-06-2003, 09:21 PM
  #5719
Originally posted by AMGRacer
Well as it happens
Mugen T0229 F/R Axle shaft 1 US$5.70
Mugen T0230 F/R drive shaft 1 US$5.00
Mugen T0139 rear up right 1 US$3.90
Mugen D0105R king pin 1 US$3.40
Mugen J0110 adjust nut 1 US$1.80
3 Racing MTX3-008 wheel adpator 1 US$5.20
10 x 15 ball bearing 2 US$2.00
6 x 13 ball bearing 2 US$2.00
I am assuming the plastic parts and other stuff you listed come in pairs.
The only reason I am saying this, is because have you ever bought serpent parts
Old 01-07-2003, 02:33 AM
  #5720
nova racer's Avatar
http://www.teamcrc.com/inventory2003/sts12.htm
nova racer is offline
Old 01-07-2003, 05:41 PM
  #5721
AMGRacer's Avatar
Latest setup which I quite liked:
Front:
70 wt oil
Fantom pistons
Yellow fantom springs
oneway
50% front swaybar
Rear:
70 wt oil
Fantom pistons
Gold Rear springs
Diff with 10K
black swaybar
maximum rear camber link angle
This worked pretty darn nice with 40 shore front and rear. Car is precice, but the softer rear springs made the rear end lazier then yellow/yellow. Was far easier to drive however.
AMGRacer is offline
Old 01-07-2003, 09:54 PM
  #5722
Taylor-Racing's Avatar
Front:
70 wt oil
Fantom pistons
oneway
50% front swaybar
Rear:
70 wt oil
Fantom pistons
Gold Rear springs
Diff with 10K
black swaybar
Hmmm . . . interesting.
We are running 50/45 oils, but it's probably appropriate for the our softer black springs.
I must confess, I've not experimented much with pistons. Are the Fantom ones much different?
Was this with the "modded" rear camber link?
While on the subject of camber links, using the Mugen rear hubs, we are still going to end up with a link that is somewhat longer than the Mugen. The Mugen being 34mm and the VoneR being 40mm approx.
I'm just thinking out loud and wondering if there is any value in moving the inner mounting outwards about 5mm. Thoughts?
Taylor-Racing is offline
Old 01-07-2003, 10:09 PM
  #5723
anyone tried or seen run the mspeed modifieds?
Old 01-07-2003, 10:32 PM
  #5724
Manticore's Avatar
with 40mm camber link length, my track width is 205mm. I need to reduse 5mm approx each side to make the trackwidth to 200mm so, it is more or less the same as 34mm on mugen
Manticore is offline
Old 01-08-2003, 07:27 AM
  #5725
Ah, yes - thanks Manti.
Hope I can get the parts before this weekend.
Old 01-08-2003, 07:28 AM
  #5726
Manticore's Avatar
The final trim to make rear end 200mm. see the length of the outter ball cap on the camber link.
Old 01-08-2003, 07:40 AM
  #5727
Manticore's Avatar
Front:
70 wt oil
Fantom pistons
oneway
50% front swaybar
Rear:
70 wt oil
Fantom pistons
Gold Rear springs
Diff with 10K
black swaybar
the fantom piston is on my purchase list now !
Old 01-08-2003, 07:53 AM
  #5728
Yes - the outer rod ends are a lot shorter, now.
Looks good.
Old 01-08-2003, 02:26 PM
  #5729
AMGRacer's Avatar
Remember that there are two types of fantom pistons. The 2001 evolution and the 2001 type. I am unsure eactly which ones I have.
The fantom pistons provide heavier damping for the same given oil weight. So with my 70 wt oil it is probably more like 100wt. Also the different hole size affects the pack rate of the oil under sharp compression. It will be best for smooth tracks,
AMGRacer is offline
Old 01-08-2003, 04:18 PM
  #5730
tl2111's Avatar
Trader Rating: 21 (100%+)
manti
Just wondering, did you do the 24T pulley mod on your car?? If you have what has involve?
tl2111 is offline
