Kyosho VoneR Thread
#5746
Re: yeah......
I wont be surprise to see people over here coming out with that mod on their V1R....
#5747
Everyone forgets that it is my idea.
I am the brains, manticore is the brawn.
#5748
you guys do know that Manitcore is a beast. so basically he should be the brawn....
#5749
You guys really likes my back, see what you talked about me at my back!!
#5750
ia it possible to put the v1rr rear 1:8th style body posts onto the mugen? (the whole RR system)
#5751
#5752
interchange...!!!
#5753
sweet
#5754
OK I just performed the MTX3 modification.
Some amendments, the king pins and the adjusting nuts come in packs of 2 so you need 2 packs of each.
I removed my kyosho V1RR rear hub and attached the mugen one without changing anything. I screwed the pivot balls in to the same as the RR, .5mm and it is almost perfectly 200mm. Also I did not have to modify the top link at all yet!
With no spacers on the Mugen hub it is almost identical to the top hole of the RR hub So we can only go up from here
#5755
Originally posted by DCR1TWO
Do you need to use the Mugen King pins or will the V-ONE R pivot balls fit the Mugen hubs? I was also wondering if you included a part number for the Spacers in your original listing.
use asso small washer set. it is around 0.8mm thich each
#5756
#5757
Oh AB we know it was your idea. No need to cry.
One questions for all yall. Don'tcha need the pivot ball pads that go between the pivot balls and the adjuster nuts?
#5758
#5759
Originally posted by HEYALIGNMENTGUY
I don't know that one since I only own a K car
#5760
I dont use them!! Kyosho does not include them
