Kyosho VoneR Thread
#1636
I notice the car accelerates well with the lightened shafts, but it's possible the car doesn't quite roll as far off throttle (although I've changed to the Kfactory chassis and notice it somehow tensions the mid belt more). It seemed my car didn't quite carry the same momentum rolling through tight corners...not in a real bad way, just need to adjust driving a bit to it.
#1637
#1638
Originally posted by kitracer
no matter how many tank I run, the mid belt is too tight.....
Can you adjust you tensioner?
#1639
#1640
Originally posted by VenomWorldOrder
just take the tensioner right of. remember too much tension on the belts will slow the car down.
#1641
Other than tensioning the belt, the belt tensioner serves another purpose. It changes the first form of harmonics created by the high RPM to other orders, thus limiting the extend the middle belt would "expand". This effect is especially predominant in cars/kits with a long belt configuration, like that of a V One R and Impulse. And remember, the higher the RPM goes, the tighter the belt's gona be and "expand" to a greater extend.
Bottomline, not very advisable to take the tensioner off...
Hope this helps...
#1642
[so what your saying mauler is the belt has "Washing machine on spin cycle" effect? the high rpm's will tend to throw the belt away from the pulleys due to the large area of belt not being pushed down.
fair enough. my tensioner hits my exhaust. doesn't seem to cause a problem though., if the tensioner wasn't there the pipe would be hitting the top deck (i just got the v1r)
#1643
hopped up v one r for sale
Im selling my back up car for my v one r if anyone is interested let me know. here are the hopups which these are from k-factory
FRONT ONE WAY, FRONT AND REAR SWAYBARS, ALLUM RADIO PLATE POSTS. LOW CENTER GRAVITY FUEL TANK, ALLUM 32T DIFF PULLEY FOR THE FRONT, ALL ALLUM PULLIES WHICH INCLUDES THE BRAKE PULLY, SIDE, AND MID FRONT PULLY, GRAPHITE FRONT SHOCK TOWER, 4MM CHASSIS WITH SPECIAL REMOVABLE CARBON FIBER PLATE FOR THE RX PACK, GRAPHITE BRAKE BRAKET STIFFENER, EVERYTHING IS IT EXCELLENT SHAPE AND YOU WILL NOT BE DISAPOINTED. ALSO A GRAPHITE UPPERDECK WITH SPECIAL RECIEVER HOUSING.
everything is in good condtion and ran it 2 times when trying out my friends os .12tr motor.
just a couple lite nicks on the bottom of the chassi everything is clean and spotless. email me at [email protected] for pics 375shipped
#1644
BTW, the belt tensioner should not be touching ur header at all... perhaps u should check out on that...
#1645
Originally posted by Mauler
Half right there... it could be bad running without a tensioner especially if ur gona run a .15 size header on ur engine... the belt's gona do the sanding of the header for you, and before you know it, it's time for another trip to ur LHS...
#1646
Where is everyone?
You're right Mauler, this site has been dead lately.
#1647
#1648
OK anyone know where in they can find a KO Vantage Esprit II radio (2 stick)? I think I'm going to run my V-One R on a 2 stick system hehehehe.
#1649
#1650
Masamimundo!
Masamimundo!
