Like Tree18Likes
Xray NT1
Old 05-13-2007, 05:34 PM
  #976
Wayne Vince took his CAN WEST sponsored MAX powered XRAY NT1 to the A Win and New Track Record at the opening round of the Ontario 1/8 On Road Racing Club Track in Hamilton Ontario Canada.
Next Race is the CAN AM CHALLENGE RC PRO Race (Great Lakes Division) May 26-27 in HAMILTON Ontario CANADA
ElliotCanada is offline
Old 05-13-2007, 06:36 PM
  #977
rmdhawaii's Avatar
Take a look at this Mugen swayblade that someone mounted on their NT1.
rmdhawaii is offline
Old 05-13-2007, 06:55 PM
  #978
kitracer's Avatar
http://teamxray.com/teamxray/news/ne...b1dc58857b5f9a
Xray NT1 came 2nd in China' biggest Race...... that was me
kitracer is offline
Old 05-13-2007, 06:57 PM
  #979
Trader Rating: 26 (100%+)
RANDY SMOOTH is offline
Old 05-13-2007, 06:58 PM
  #980
Congrats to you!! Glad to see the car is doing well...
DaNNy671 is offline
Old 05-13-2007, 07:00 PM
  #981
thats not my car with the mugen blade but i did fit it up before heading to the track and found out that the mugen ball ends on the blades are bigger than the xray joints and i didn't have time to retrofit before leaving so i left that project for this week .
i plan on adding some adjustable links as well for tweak adjustments
nice work on the blades
Nitrogasm is offline
Old 05-14-2007, 01:00 AM
  #982
Congrests man!
_cyclops_ is offline
Old 05-14-2007, 02:37 AM
  #983
rmdhawaii's Avatar
Originally Posted by Nitrogasm
yes sow the knuckles were a direct replacement , the bearing sizes are different so you need to use mugen bearings , cvd's and the ball joints .
here are pix of the mugen hard foam bumper and the mugen 136b knuckles
i agree 100% about the part interchangability if another brand part works to keep you racing do it.
it's all about finishing the race
Just wondering if you measured these points before and after replacing the front hub.
Old 05-14-2007, 02:54 AM
  #984
Sow&Steady's Avatar
That's a very good point RMD, I did a quick check and from pivot to pivot, its about 30mm for both the NT1 and the MTX4's original uprights (actually its the same with the 720 too). I think the MTX4 type-B is the same, only difference is the lowered steering link/arm.
Sow&Steady is offline
Old 05-14-2007, 07:04 AM
  #985
to the best that i could measure it was the same using the 136 knuckle and using the 136b the only difference is the steering arm being in a lower position like sow said.
Old 05-14-2007, 09:06 AM
  #986
vc05hdt's Avatar
Originally Posted by bvoltz
Yes... The OS 1040 L52 pipe... I have noticed when using this pipe, better performance from the OS engine and it did run cooler, but this could be my location I live a place that the devil himself comes to vacation... (remember most go to a place that is warmer then they are current at... ) Jackson, Mississippi... nothing like 98 Degrees and 100% humidity...
vc05hdt is offline
Old 05-14-2007, 10:02 AM
  #987
mtveten's Avatar
Trader Rating: 29 (100%+)
Thanks for the info and the photos. What are your thoughts on distributing the weight versus putting it in one place? Perhaps not equally and using the other holes in the chassis.
I have never done any static weight balancing or seen it discussed in the forum, so looking for some additional thoughts on this. Thanks!
The idea is to balance the car's left/right weight distribution to provide more symmetrical handling. I prefer to start with the ballast as close to the front/rear centerline since that yields the least impact on the car front/rear bias.
The best way to balance the car would be to use 4 scales with each wheel centered over 1 scale. With the car on the scales you would then add weight to the heavy side to make the left & right side of each end perfectly match while maintaining the front/rear weight differential.
Although scales are needed to make perfect adjustments I have found the simple balance pins to be much faster, easier and in practice just as good; providing you can place your ballast close to the front/rear center line.
With a Nitro car it is important to check balance both with dry and full tanks since most cars don't have their fuel load perfectly centered. After you figure the ballast required for both dry and full you should split the difference giving you the closest possible balance throughout each stint.
Mark
mtveten is offline
Old 05-14-2007, 12:20 PM
  #988
rmdhawaii's Avatar
Excellent write-up! Thanks Mark
Old 05-14-2007, 12:24 PM
  #989
rmdhawaii's Avatar
Novarossi Engine Mounting Tech Tip:
http://forum.teamxray.com/viewtopic.php?p=51026#51026
If you own a Novarossi based engine, make sure you read this one.
Old 05-15-2007, 04:21 PM
  #990
x ray lack the guts to show the competion again. what car was first?
LORD SHADO is offline
