Like Tree18Likes
Xray NT1
Old 03-17-2015 | 07:53 AM
  #7276
GREGORY!'s Avatar
The car were sent in some factory drivers for test it around one month ago.
So,they have do their homework.
GREGORY! is offline
Old 03-17-2015 | 10:21 AM
  #7277
vernon7026's Avatar
Hello all
I am looking to purchase a 2nd hand Nt1, I have 2 Schumacher MI5's (love em) but also want to get into nitro !
If i needed parts to overall engine ( RB 12) where would i get these ?
This is in the UK !
Regards
vernon7026 is offline
Old 03-17-2015 | 03:00 PM
  #7278
kchamp's Avatar
Originally Posted by goop
the mugen one is a very nice starter box
I have the Mugen Mugb0236 box but cant get the starter wheel to line up with the flywheel. Any Ideas?
kchamp is offline
Old 03-17-2015 | 08:44 PM
  #7279
Scott B's Avatar
Originally Posted by Scott B
If I recall the silver kit springs are 33/28lbs and they are not the progressive springs.
Originally Posted by 1evo RRR Driver
Fellas quick question, anybody know the spring rates of the silver springs that comes with the 14wc.??
Do you try the search button Chet...
Scott B is offline
Old 03-18-2015 | 01:19 AM
  #7280
JamesHealey's Avatar
Originally Posted by vernon7026
Hello all
This is in the UK !
Regards
Answer RC sell RB engines and spares, they can order anything not on their website.
JamesHealey is offline
Old 03-22-2015 | 11:52 AM
  #7281
MrHistory's Avatar
I would recommend the nt1 2013 with short shocks if you run on high traction tracks without the tire handout system. If running in a controlled tire setting maybe the nt1 2014 is the way to go.
From what I see in the USA the 2013 is still the best nt1 kit out and being run at big races by the top drivers. The 2014 does not work as well on US tracks
Hello all
This is in the UK !
Regards
MrHistory is offline
Old 03-23-2015 | 11:46 AM
  #7282
From: El Pueblo de Nuestra Señora La Reina de Los Ángeles del Río de Porciúncula, California, Unites States of America
I have a 2013 NT1 for sale. FYI. Haven't posted it for sale just yet.
lagcisco is offline
Old 03-23-2015 | 02:43 PM
  #7283
MrHistory's Avatar
So where is this new car?
Old 03-23-2015 | 05:39 PM
  #7284
I saw somewhere that said it was "all-new" but I somehow don't believe that.. NT1s still seem to do well everywhere plus they just hot off a Worlds win as well. Maybe alu bulkheads with bearing supported sway bars at most?
lagcisco is offline
Old 03-24-2015 | 04:28 AM
  #7285
+1
I'm going to stick with my 2013 for a while, just switch between short and long shocks.
JOE SI is offline
Old 03-24-2015 | 08:27 AM
  #7286
MrHistory's Avatar
I agree. My best guess is that the entire drivetrain and plastics (excluding bulkhead assemblies) will cross over. It will be interesting to see xray transition to the aluminum format they have so resisted and believed was inferior. They adamantly defended the plastic bulkhead design when introducing the RX8.
It would seem that the car will have some new handling characteristics even with same geometry as current car
Old 03-28-2015 | 03:46 AM
  #7287
I just read the interview about new nt1 on redrc. It seems xray is becoming like all other businesses and must make cost/benefit compromises. The change to alu bulkheads seems to be driven by costs, not superior performance.
There is also small lie/overlooked error in the article. They do not have a chassis in EVERY on road class. What about large scale onroad? Where is their car for that? And trust me, i would be first in line shouting take my money.
balum_balum is offline
Old 03-30-2015 | 01:05 AM
  #7288
vernon7026's Avatar
Hello all
I just bought a used nt1 (2011)
The out drives are worn ? Do I need to change drive shafts or just the
Out drives ?
Also the front diff has a leak is it better to have solid
Front axle or diff ? As I do have the bit to fit inside front
Diff to make solid and if solid do I still need diff oil ??
Hope you can advise
Old 03-30-2015 | 07:13 AM
  #7289
Scott B's Avatar
Hello all
Out drives ?
Hope you can advise
If the outdrives and pins on the axles are worn then yes it's best to replace both.
If the diff is leaking you can either rebuild and use new seals or use the block to make it a solid axle. The choice would be yours on how you want the car to handle and track conditions.
Scott B is offline
Old 03-30-2015 | 08:48 AM
  #7290
vernon7026's Avatar
I am not sure what to do
I have 2 Schumacher mi5's with a spools up front !
What is the difference between the two ?
If i put the block inside the diff, then i take it i dont put oil or O rings etc etc
