Xray NT1
#6526
Zero Force Xray NT1 Bearing Kit Set
#6527
NT1 Gurus assistance required!
Hi
Tried to install my STS into NT1 tonight and found the gear mesh tight with it. At first I thought it might have needed shims behind the collet, but that really made no difference. Is it simply a case of the holes on the crank case being different? And is there any other way to adjust it?
I ended up taking it out as it will just strip being that tight.
Help appreciated as always
Andrew
Andrew
#6528
First try loosening the upper engine mount screws and then re tighten them wile you are still pulling the engine apart from the spur gears. If still to tight just widen the mount holes on the engine's case.
Hi
Andrew
Andrew
#6529
Can I identify that I have hobbyshop and we sell xray NT1 Spareparts and items?
#6533
In malaysia. This is my website : www.trusthobbyracing.com . Currently we are not updated yet but you can send me a message at [email protected] if you need anything .we are the distributor of many items too such as murnan modified engines, hot race tyres,hipex exhaust and kosmic fuel .but we sell xray parts too at a very affordable price..
We sell worldwide
We sell worldwide
#6534
NT1 2 option parts
#6539
Hi,
any idea what is the height difference between lower engine mount & the original standard engine mount???
