Xray NT1
#7066
double post
#7067
I mean the bearings located in the rear bulkheads, where two speed shaft sit...... or where the rear brake pulley sit..... the main shaft.
( Not the bearings inside two speed spur gear housing )
#7068
aaaaaaaaaaaaaaaaaaaah , yes I lube those ......
#7069
So how was it when you found that out? I'm just wondering how blown it was. Mine was, as you saw, one wheel was pretty much stuck due to melted bearing.
#7070
I had a cracked composite gear inside the diff. I noticed it because when I would turn the front left wheel, it's the only one that would turn, when all 4 should. No melting bulkheads or anything like that, we have aluminum bulkheads in the mtx5
#7071
I change them but not that often .....probably 6 races for me
#7073
Helli guys! Does anyone know anything about nt1 gimar edition?
#7074
#7075
#7076
What is the internal diameter of the new low profile shocks?12mm?
#7077
Just wanted to say how kick a** this car is! First weekend out with the car and placed third in the nitro expert A main. Car felt pretty darn good and now just need to work on getting a little more rip out of the corner and a tab more off power high speed steering out of the car on corner entry. I definitely look forward to running this car again in the near future and way to go Xray with a solid Nitro!
#7078
I'm just curious, what's the difference between using rear universals or dogbones?
IMO the car feels better with CVD's but on the same track with both, the faster laps were with dogbones
#7079
