Xray NT1
#6826
#6829
#6830
#6832
Try front 4.5 and rear 5 mm ride height on blank rims.
#6834
#6835
#6836
I tried 59/61 split with a ride height at 6/7mm just for kicks. The car had tremendous corner speed throughout the whole transition. I was able to accelerate before hitting the apex on corners at my local track. And the funny thing is that this was only the 2nd run before really touching set-up. Pretty sweet car.
#6837
where does that put u with foam? like 8.5/9mmI would try short rear link, more spacers on top of the rear knuckle, and maybe one hole up from bottom on rear roll center.......even raise rear shock up 1 may help.....
#6838
#6839
the shocks are lower so you have lower RC. than say the 2012.
The shocks are more inclined also if you use the same hole.
Both those will get you more grip so also less steering.
What evo driver says is also good. You need to raise the rear RC.
18Likes
