Xray NT1
#6286
Front gear diff here.
#6288
front diff , 150K oil
#6290
Super lightweight solid axel
I was after some advice on the super lightweight front solid axel. It has about 3+ mm play and doesn't seem to sit on the pin properly. If I was to push it, the pulley that is , the pin only sits half way in the hub/holder. Anyone else experienced this? Can it be shimmed ? Do the shims in the NT1 kit fit? Is this why everyones running gear diff ? I have built a killer car and it seems to be the only problem. My local track, a solid front is usually way to go, also I like the idea of such a low rotating mass up front. But don't think I want to run my car with a half captured pin. Why would X-ray do this .. It doesn't seem right. Any help would be more than appreciated.
#6294
gonna weight mine this week......
#6295
ARENA New released US 7075 T6 Alu. Hardcoated 2012 Spec Chassis for NT-1
#6300
Guest
fuel pressure
I bent the tip on my muffler which caused a crack around the weld area and it's really fouling up the way the motor runs. Anyone got a good tip on patching the crack?
