Like Tree18Likes
Xray NT1
Old 05-27-2011, 02:20 PM
  #6001
NikoRacing's Avatar
Originally Posted by RC MARKET
CSO 3.5mm Graphite Chassis 2011Spec
Hello boys!
I bought just now a 2011 chassis with its brass weights ...I will clean the car next week and cant wait to change the old one for the new
..but I'm really curious to know how this carbon chassis works.. Is anybody using it? How is the car in camparison to the aluminium chassis?
How is the durability and how is it with crashes? Are the screws-holes precisely machined?
thx
for RCMARKET: can I mount the weights on the 2011 carbon chassis?
NikoRacing is offline
Old 05-27-2011, 09:23 PM
  #6002
jds5150's Avatar
Originally Posted by NikoRacing
Hello boys!
thx
I haven't tried the latest 2011 carbon chassis but the previous version worked pretty well. It has more flex and it helps a fair bit in cornering. It will survive light to medium crashes. I've never broken mine yet but if you hit the boards real hard, you will bend the toughest 7075 chassis. I would recommend carbon upgrade if you are after more traction especially in cooler climates.
I presume you can mount the brass weight on the 2011 carbon chassis or there isn't any point releasing a new version.
jds5150 is offline
Old 05-31-2011, 07:51 AM
  #6003
What life receiver battery will fit in the nt1!? I purchased a life battery from protec Rc and it will not fit. I want to reduce the weight of the car.
HoboShop is offline
Old 05-31-2011, 09:14 AM
  #6004
ToysRUsKid's Avatar
Trader Rating: 16 (100%+)
I use the life packs from IP. I think I ordered them from RCMushroom back in april and it took about 12 days to get shipped. I also had the same trouble with the PROTEC battery. The casing on that battery is way too big.
ToysRUsKid is offline
Old 05-31-2011, 12:08 PM
  #6005
Thanks alot for the info I will look in to it.
HoboShop is offline
Old 05-31-2011, 06:16 PM
  #6006
Trader Rating: 28 (100%+)
The Orion Life 1300 pack will fit... just barely, but it does fit.
Scott Fisher is offline
Old 05-31-2011, 09:16 PM
  #6007
Thanks Scott!! Where can I get it from? And how much?
HoboShop is offline
Old 05-31-2011, 11:48 PM
  #6008
http://www.horizonhobby.com/Products...rodID=ORI12255
I was wrong, its an 1100. This is what I have run in my RRR and now my NT1 for a while. A few of my friends run this battery as well.
Old 06-01-2011, 08:08 AM
  #6009
Is it small enough that the steering servo horn doesn't hit it when it goes back?
younghovaa is offline
Old 06-01-2011, 09:08 AM
  #6010
This is the only battery that I have ever run in my NT1. Like I said, its a tight fit but this is what is always in my car.
Old 06-01-2011, 02:10 PM
  #6011
Riketsu's Avatar
Trader Rating: 34 (100%+)
If your servo horn hits the battery, no matter how big it is, its probably not trimmed correctly (because the center pulley mount won't allow certain sizes).
The horn is not supposed to be 90 degrees, but a few degrees forward. Always check that the EPA are set correctly or you'll blow a servo for no good reason.
Riketsu is offline
Old 06-06-2011, 01:39 PM
  #6012
piper48
Guest
Posts: n/a
Default NT1 camber
I bought a used NT1 not to long ago and just ran it the way it was setup by previous owner. After 4 club races I noticed that the tire wear front to back was uneven due to aggressive camber setting (-4 deg rear and -3 deg front). So I set it up with the same camber settings from electric tc (-2 deg all around) and now the outsides are wearing out much faster. I was wondering if -3 to -4 deg camber is a normal setting for these cars? Any camber suggestions would be much appreciated.
Old 06-06-2011, 01:43 PM
  #6013
Riketsu's Avatar
Camber values should be between 3 to 4 in the rear... and usually 1.5 in the front. This will all depend on the layout of your track, and your suspension settings.
The softer the suspension, the less camber you'll need. The front camber I usually use it to achieve more or less steering quickly (before a qual or main). So that's why I start out at 1.5 so I have room to adjust.
The rear camber should be adjusted until the tire starts to wear slightly conical to the inside.
Riketsu is offline
Old 06-06-2011, 02:15 PM
  #6014
etgdpu's Avatar
Default clutch soring length
Hi,
Could you please let me know how long is the hard centax spring from xray?
etgdpu is offline
Old 06-06-2011, 05:00 PM
  #6015
ToysRUsKid's Avatar
1-2 in the front or 3.5-5 in the rear on the car is not unheard of. check the setup sheets on www.xray.com.
