Like Tree18Likes
Xray NT1
Old 01-19-2009, 02:38 PM
  #3646
rx7ttlm's Avatar
Trader Rating: 30 (100%+)
anyone have a good aftermarket side belt tensioner for use with 25 tooth front pulley?
rx7ttlm is offline
Old 01-19-2009, 03:00 PM
  #3647
thanks for the pm about the engine.
regarding the tensioner, get the km racing tensioner works great i have one. you can buy it online from km racing directly as well! they also have some nice alloy parts like the front layshaft block, and rear lower pin support block.
TomB is offline
Old 01-19-2009, 06:46 PM
  #3648
rx7ttlm's Avatar
you can actually tighten the belt enough with the 25 tooth pulley? I tried it with the stock tensioner at max knowing it wouldn't be right, after breaking in my new engine I had three teeth missing, I was like FAIL lol. Know how I can get one by friday without international expedited shipping?
rx7ttlm is offline
Old 01-19-2009, 07:25 PM
  #3649
yeah it isn't just a copy of the xray belt tensioner, it actually has a larger swing so you can tighten the belt down alot more
TomB is offline
Old 01-19-2009, 10:17 PM
  #3650
rx7ttlm's Avatar
ok, so your sending me one so I can run my happy new setup this weekend and not kill side belts? lol
rx7ttlm is offline
Old 01-19-2009, 10:24 PM
  #3651
rx7ttlm's Avatar
BTW, I went away from my usual setup and tried some new things last weekend and the car was fast as hell even while breaking in the new engine.. Never thought I would use the light red 38.5 front spring but it worked pretty well sunday at CP, EASY to drive.. might run the light purple and try that.. Will post setup on Xray site later.
cheers
rx7ttlm is offline
Old 01-19-2009, 10:58 PM
  #3652
rcfoolz's Avatar
Trader Rating: 22 (100%+)
cheers
did you try the FT Myers setup?
rcfoolz is offline
Old 01-19-2009, 11:33 PM
  #3653
rx7ttlm's Avatar
nah, went with something remotely similar. It was the same idea, a stiff as front spring to get the car to point. and overdrive so it pulls through the corner.. I usually use the 26 tooth pulley almost exclusively. went with the 25 tooth.. I have a couple changes to make, I was concentrating on my engine break in and didn't make any changes to the chassis..will set up the backup car with ft myers setup and throw it on the track during practice.. its actually a really technical layout compared to the last one.
rx7ttlm is offline
Old 01-21-2009, 11:28 PM
  #3654
flylow's Avatar
Talking NT1'09
What option part include in NT1'09 ???
flylow is offline
Old 01-22-2009, 12:18 AM
  #3655
rx7ttlm's Avatar
No info yet, waiting till the the ring toy fair..
rx7ttlm is offline
Old 01-22-2009, 12:37 AM
  #3656
For 09' it will include more "made in China" parts.
hello is offline
Old 01-22-2009, 12:43 AM
  #3657
jfc_tech's Avatar
jfc_tech is offline
Old 01-22-2009, 06:32 PM
  #3658
rx7ttlm's Avatar
Originally Posted by jfc_tech
Yeah, I am not sure whats up with that. But My last batch of Orings that came in had Made in china on them.. i was sad face
rx7ttlm is offline
Old 01-22-2009, 09:37 PM
  #3659
Trader Rating: 15 (94%+)
I hope they do something to cure the rear belt strip issue that me and some others have
mrgsr is offline
Old 01-22-2009, 10:23 PM
  #3660
rx7ttlm's Avatar
Do you use the stock belt? dirty track? do you change them before they show wear? I have had as much as 4 hours on a rear belt before I decided to change it before it lost teeth.. tighten the eccentric one slot and that should help
cheers
rx7ttlm is offline
