Xray NT1
#3601
grip? with decent grip I usually start in the pink range(light purple as xray calls it), 600/1 F and 600/2 R, front arm at top roll center position(one up from stock), rear roll center inner arm pivot one up from stock(raising rear roll center), rear diff 80k (I run as thick of oil as I can without snap oversteer), spool front. maybe try violet all around if the grip is low, and also drop the weight of the rear diff oil, and play with shock oil, another combo that works well sometimes is 600/2 and 500/1 or 2. the heavier diff oil and roll center changes seem to be the biggest changes.front bar flat if stock, about 45 degrees if you have the .7 bar. cheers.
yes had grip , i'm used F & R lightpurple ,
F 650cst 2 / R 650cst 3
3 toe-in
camber F 2 / R 3
F roll center std
R is lower
rollbar F 0.7 R 2.2mm
F 4.5mm R 5mm
Downstop F around 3 R around 6-7 small flow
Tire 38 /38 F 58mm /R 60mm
F 300000 & R 80000 Gear diff
very hard to drive in high speed corner , the car feel not have any grip !
in small turn not have big problem .
i'm want EP car feel .
#3602
Hello from France,
I update my presentation.
http://www.automodelisme.com/index.p....msg397837#new
Au revoir
Au revoir
#3603
hello guys,
this is my second season racing my NT1/Maxpower XXL3 (new engine) here in kuwait, last year finishing 3rd in the nationals and winning the first trophy for the NT1 here in Kuwait, 2 weeks ago started the season here and took 2nd place in our first points race, just wanted to share with you my low traction set-up, just change the Rear toe to 2.5 (better).
and if you find the car understeering in mid and corner exit, just lower the front roll center by going up to +o.5 position.
http://forum.teamxray.com/xform/inde...=811&setup=nt1
cheers
Ali
cheers
Ali
#3604
hello guys,
cheers
Ali
cheers
Ali
Btw, how is the engine performing under the dessert weather ? Do you guys still racing / practice in summer time ? What is the highest temperature in Kuwait city ? Sorry to ask so many questions .
See you around.
#3605
Hi,
Does anyone know any place with a really good price on the Xray NT1 kit ?.
I have some thoughts of maybe start with nitro touring this summer, and looking at the NT1 mainly beacause i have a T2´009 today and is really happy with it
#3607
#3609
Hi Ali, Welcome to nt1 forum. Congratulations on your winnings.
See you around.
See you around.
hey thanks for the interest well, right now, it aint desert weather anymore since the temp drop to -1C to 14C thats freezing cold.... the engine is more than great, i run it with 30% nitro fuel. and hell no we dont race during the summer, our season starts in october and ends mid april...the temp in july/august goes all the way up to 58C thats around 135F..
cheers
Ali
#3610
cheers
Ali
cheers
Ali
You got PM ( Personal Messages ), click on top right on your screen.
I have Xray NT1 and Mugen MTX4.
See you around.
#3611
